Hello.
I need help to troubleshoot my Vantage Pro transmitter.
The problem started with early morning data loss. Just before sun rise, all data from the transmitter would cease. After I would notice this and hit the "
done,
- " button combination on my display, I could re-acquire the signal. For a day or so. Then it would happen again.
A few days ago the signal stopped and I have not been able to regain it.
I checked the battery and it was nearly dead. Had a little over 1 volt in in it. Thing is though, I just replaced that battery this spring.
This sounds like the VP2's
super cap failure but the VP1 has a different capacitor and I have not heard anyone mention this sort of failure with that model. I pulled the board off and looked at it and the capacitor ( 5.5volt, 1F) does have a very little bit of a substance on one side (the cap is flat and round - about the size of 3 quarters taped together) that looks like dried honey but it doesn't appear damaged.
I had an older CR123a battery that still had 2.5 volts in it so I stuck that in this morning but I still have no signal.
I have also tried running the transmitter without battery hoping the Solar Panel could do the job but that didn't work either.
So -
Does this sound familiar to anyone?
Does anyone know if there is a test point on the VP1 I could use to check the solar panel voltage?
Any and all tips are really appreciated.
J0e
