I was nosing around the site and also found this.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G17171
I wonder what the current out put is? I assume it puts out 12+ volts in full sun?
Testing G163191 panel and Davis panel with Davis fan.
G163191 18v full sun no load
G163191 15v partial sun no load
G163191 1.3v at fan @ 60 ma motor runs
G163191 .05v cloudy 30 ma motor won't run
___________________________________________
Davis solar panel 2.0v full sun no load
Davis solar panel 1.3v full sun @ 60 ma motor runs
With one panel in full sun, the motor will run. This is no better than using the Davis panel.
With one G163191 panel on a cloudy day, the motor won't run.
To make the motor runn full speed, I want a more voltage to drive 100 ma through the fan.
I'll try two panels in parallel, then all 4 in parallel.
