Overtightening the guy wires or placing them at the wrong level can also bring a tower/mast down, but being in FL I'd bet corrosion was the cause here. Some months back a Ham died when the tower he was disassembling fell, probably because they guys were maxxed out so when one snapped the others pulled it too hard and it collapsed under him. I had a 42in J-pole antenna made of 1/2 in copper pipe atop 3 ft of 1 1/4 Sched 40 PVC on my mast when I recorded a 70MPH gust 10 feet below the bottom of the antenna. And to top that off, the antenna/PVC pipe connection was a 3/4 in screw-thread PVC reducer fitting which I figured was a weak point. That's a lot of leverage on the pipe and fitting but it held! PVC deteriorates with UV exposure so if it's 5 years old and you've got to take it down for other work, go ahead and put new pipe up in it's place- it's cheap insurance.
The only PVC mast I ever lost was 20 ft of 1 in Sched 40(2 sticks) and guyed only at the top. It didn't fall but the compression load from the guys turned it into a series of curves which got worse quickly after I retightened the guys so I had to junk it all. Next time I'll stay about 1/5 down with the top guys, leave them on the verge of loose and add another set of guys maybe halfway up and slightly tighter. The PVC will flex quite a bit before breaking and that should take this into account without adding compression.
The best 'bang for the buck' is chain link fencing's "Top Rail" pipe. About 1 1/4 inch, galvanized, and can be had in up to 16' sections. Not as good as the TV antenna pipe but OK for lightweight or low wind load use (such as a WX station) it'll hold in at least 100 MPH winds which will usually have already taken out most mounts or whatever they (used to be) tied into
With a freestanding "top rail" mast I'd guess you could go 12-13 feet without a problem- more than that and I'd guy it appropriately.
