Wow, an already established note for what I wanted to talk about!
About two months ago I started thinking about standing up a PC totally dedicated to my weather station, and wondering about how low I could go with power, size and storage without having to really shoehorn anything together. So I was thinking small, but at the same time I didn’t want to expend too much effort as well. So I was poking around Tiger direct, and lo and behold came upon an Intel mini-ITX motherboard with a single core Atom processor. After a couple days of quality time with Google and “mini-ITX” I had ordered the parts for a system (it’s been years since I put a system together, so this was kinda fun too!).
The guts of my weatherstation PC:
Intel single core 1.6ghz Atom processor motherboard A caution on this motherboard: older stock has a heatsink that’s too tall and you need to buy an optional, shorter one to work in most mini-ITX boxes. Ask the seller which height you’re getting, or, at this point spring for the extra ~$20 and get the dual core version mentioned below which comes with the shorter heatsink.
Mini-Box M200 caseMini-Box 90watt power supply A caution here too: older stock has the wires to the SATA power conector coming off the side, rather than the end of the connector which doesn't work for connecting to a surface-mounted SATA drive (the M200 box's mounting method). Ask the seller to send you a power supply that has the wires coming into the end of the SATA power connector.
Patriot 32gig SATA SSDKingston 2gig DDR (why 2gig? As cheap as memory is, why not?)
The SSD is overkill, but the PC’s application has expanded to include running some of my USB-based audio/visual equipment as well, so the extra elbow room for storage was welcome. Also, if I had to do it all over again, I might choose the
Morex 5667 case and power supply instead of the M200 and picoPSU-90 power supply.
I also bought an external optical drive to initially bring up the system with:
HP dvd1040e 20x DVDThough if you have an old PATA or SATA optical sitting around, I’d cable it up externally (temporarily) and avoid the cost of the external. Once I was up and running and connected to the network, I got everything from the network, so I disconnected the optical drive.
I’ll supply more details later (as well as some pictures), but suffice to say anyone who is very comfortable cabling together a stereo system can put this PC together, though there are some tight spots that you have to deal with.
Also, I became so enamored with how small the box was, I put together a second system almost like it, but substituting a 2.5” SATA HDD and the
Intel dual core 1.6ghz Atom processor motherboard (this one comes with a shorter heatsink, unlike the single-core one mentioned above). I’m pushing this one to see just how much it’s capable of, and so far I’m pretty tickled by its performance (I’m using it now to compose this post). So far I’ve only seen hesitation on 1080p movies and Google Earth, and the slight hesitations in Google Earth are easily tolerated. If you’re a heavy multi-tasker it’d probably bog down but I’m a serial kinda guy so it works just great. And given I have the box mounted up UNDER my desk, I’ve got a lot more [physical] desktop than I did when I had my huge system up on it!
mini-ITX resources to start your research:
http://www.mini-itx.com/ (already mentioned)
http://www.e-itx.com/ (motherboards, cases, power supplies and barebones)
http://www.mini-box.com/ (motherboards, cases, power supplies and barebones)
http://www.logicsupply.com/ (motherboards, cases, power supplies and barebones)
By no means exhaustive, but a good place to start. As for 2.5" drives, etc. I'm a big fan of
TigerDirect.com which is where I got the 32gig Patriot SSD for $90!
Hope this helps, if you’ve got any questions, I’ll try and answer them! I need to dig a system out and take a picture of it against somethig for scale.
Roak
Ps. Not mini-ITX, but for about the price of just the XP Pro license alone, you can get a
refurbished HP XP Pro desktop from TigerDirect.com
