Author Topic: menubar.php vs flyout  (Read 1365 times)
Offline floodcaster
    • Goose Lake Weather
« on: January 03, 2009, 10:20:52 AM »
Just downloaded Ken's great php scripts and have started to customize. Probably will be a while yet before I go "live" with the new ones. Am curious if there are any particular advantages of using the fly-out menus vs the menubar? Probably more questions to come... ;)
WD forum is down at the moment so didn't have a chance to search there.
Bill
Re: menubar.php vs flyout
« Reply #1 on: January 03, 2009, 10:52:51 AM »
Hi Bill,
Which menu system to use with the template set most likely depends on how many pages you plan on having on your website.  If you have 10 or less pages, then the menubar.php will create a linear list of the links for navigation.
If you have more than 10 pages, then a linear list may be more difficult for your viewers to navigate, and the flyout menu makes it easy to group related pages and quickly navigate your site.  It also has the side benefit of creating a single-page sitemap showing all the pages on your site.
The flyout-menu is a bit tricky to configure as the flyout-menu.xml requires perfect XML syntax (or else the whole menu system doesn't work), but it's easy to add items/test (using flyout-menu-test.xml and ?menu=test on the URL) in a parallel environment, then when the menu looks fine, copy flyout-menu-test.xml over flyout-menu.xml and upload flyout-menu.xml to implement your changes.
Hope this helps...
Best regards,
Ken
Offline floodcaster
« Reply #2 on: January 03, 2009, 11:06:27 AM »
Thanks Ken. That's the info I was looking for. :-)
Bill
Bill
