Author Topic: Maplin N23DQ / HP1000  (Read 1122 times)
Offline flames7607
« on: July 29, 2018, 12:47:58 PM »
Hi Everyone,
Had my station for about 1 year (previous one replaced by Maplins when it developed the same fault)
The remote array is not being picked up by the consul. I've done all the usual resets with battery removal, power down the consul etc as described in the manual, the Fine Offset website etc.
I've also updated the firmware, the frequency in the "main"  file is set to 433, and the firmware has updated correctly.
The indoor sensor (temp and pressure) is being picked up by the consul, but not the remote sensor ( 10 feet from consul, fresh batteries etc)
The LED on the remote consul is flashing every 16 seconds.
On the "about" page the ID of the indoor transmitter is shown as 11, but there is no ID shown against the outdoor.
I've carefully opened up the remote unit. There is no sign of water ingress or corrosion.
Can anyone suggest anything else I can try please ?
Secondly, within the "main" file, the following is listed
[Option]
WH26=false
Transmitter=WH24
Frequency=433M
Does anyone know what the WH24 means, and should the WH26 be different ?
Any help appreciated
