Author Topic: What File to Force a "$NOAAEvent" Value?  (Read 606 times)
Offline Breezy
  • Indian Trail Weather
« on: March 14, 2018, 06:37:47 PM »
For testing purposes I would like to be able to force a NWS alert, "$NOAAEvent", to either a value or null. Within the "nws-alert" programs which file and where can I insert this testing value?
Thanks folks ...
Jeff
W7-64, Intel Z170A 16 GB RAM
Re: What File to Force a "$NOAAEvent" Value?
« Reply #1 on: March 14, 2018, 07:52:15 PM »
Ummm... $NOAAEvent is in testtags.php and created by Weather-Display.
In the testtags.txt template you could change
$NOAAEvent = '%NOAAEvent%'; // NOAA Watch/Warning/Advisory
to
$NOAAEvent = 'Some Urgent Warning Here'; // NOAA Watch/Warning/Advisory
and have WD upload testtags.php.
Keep in mind that the default Saratoga template doesn't use that tag anywhere, nor does the nws-alert set of scripts.
Offline Breezy
« Reply #2 on: March 14, 2018, 08:02:30 PM »
Thanks for the info. Ken. I thought that it might be in the "nws-alerts" set of scripts. I like your solution  \:D/ I wish that everything was as straight forward. I'll give it a try. Much appreciated!  =D> My question should be directed to Brian as to where he uses "%NOAAEvent%".
« Last Edit: March 14, 2018, 08:05:23 PM by Breezy »
Jeff
