Author Topic: Temp indication locking up  (Read 1513 times)
Offline pwdiver
  • Beach Area Weather
  • My 1972 Challenger
« on: May 04, 2017, 07:00:38 AM »
I was wondering if anyone else has had a problem with WD locking up the Temp indication not updating, Im not sure if its the software or could my CC-2000 data logger Ive been using for years be the problem or for that matter my MK-III-LR station :?:
Offline waiukuweather
Re: Temp indication locking up
« Reply #1 on: May 04, 2017, 01:48:32 PM »
do you mean like flat line on the graph, or?
does the other parameters change when the temperature does not, or?
Offline pwdiver
« Reply #2 on: May 04, 2017, 08:15:35 PM »
I just got home and looked everything has flat-lined I dont know if its the software im gong to unplug my data logger and see what happens when I plug it back in #-o
« Reply #3 on: May 04, 2017, 09:19:02 PM »
so its just not the temperature
its that no new data has arrived or been processed
was the data received light still flashing?
one thing, make sure windows is not powering down the usb (selective power)
Offline pwdiver
« Reply #4 on: May 05, 2017, 07:33:37 AM »
Ive got it set to never sleep but if you look at the advanced parameter's USB is enabled which I disabled and hard drive was set to 20 min it doesn't give the option to disable this I changed to 10000. :?:
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« Reply #5 on: May 05, 2017, 07:58:23 AM »
set hard disk to 0
Kind regards
Bashy
