Please let me know your thoughts. All constructive criticism is welcome!
https://www.txweather.org
Regards,
TXWeather
Your link
https://www.txweather.org displays a list of files in your top folder.
Index of /
Name Last modified Size Description
Base-USA/ 28-Mar-2019 12:14 -
comingsoon_03/ 26-Mar-2019 20:50 -
favicon.gif 27-Mar-2019 04:50 0
favicon.ico 27-Mar-2019 04:50 0
robots.txt 07-Dec-2015 15:06 367
weather28/ 22-Dec-2015 17:42 -
Better add an index.php in your top-folder to directly go to your main Saratoga template site.
An example can be found in
https://www.txweather.org/weather28/_my_scripts/, its name is zz_index.php or use this example:
<META HTTP-EQUIV="refresh" CONTENT="1; url=./Base-USA/index.php">
The user is than directed directly to your main site.
Be aware that your old version of the Leuven-template site is not the updated one which is compatible with https.
You should download the latest version if you want to use the Leuven template with https.
When you leave it as it is now, your error-logs will be filled by bots accessing it and most providers do not like that.
Wim
