Author Topic: Wireless IP Camera with IR light  (Read 11766 times)
Offline Axelvold
« on: December 30, 2011, 03:48:49 PM »
I have ordered 2 Wireless IP Cameras with IR light, and now I'm wondering how will the IR light be effected if I put the camera in front of a window?
They are for indoor use, but if I get a good enclosure could they then be mounted outside?
Lars Magnusson
Axelvold / Sweden
55° 57' 41" N / 13° 6' 1" E
Offline WeatherHost
Re: Wireless IP Camera with IR light
« Reply #1 on: December 30, 2011, 04:15:19 PM »
The IR will reflect off the glass blinding the camera.  I'm not sure why, but it does.
I picked up one of the Foscams and am working on an enclosure for it.  With the IRs on, I see nothing.  At least I can turn them off from the web page.
Offline d_l
  • Slide Mtn - Mt Rose
« Reply #2 on: December 30, 2011, 04:33:23 PM »
How can you weather enclose it if any glass in front of the IR LEDs will blind the camera?
--Dave--
Offline WeatherHost
« Reply #3 on: December 30, 2011, 05:04:22 PM »
Like I said, I can turn the IRs off with a mouse click.  I'll use other lighting outside the dome if I need it.  You can buy separate IR floods or just use standard visible yard lighting.
Mine will be about 40' up in the air, so the built-in IRs won't be useful anyways.
Offline Axelvold
« Reply #4 on: December 30, 2011, 05:53:14 PM »
Lars Magnusson
Axelvold / Sweden
Offline WeatherHost
« Reply #5 on: December 30, 2011, 06:25:14 PM »
I don't know exactly what would happen facing a glass window, but this is what happens with the IR on inside a lexan dome:
Offline sebeclake
« Reply #6 on: December 30, 2011, 09:48:08 PM »
This kinda explains it: http://www.dandydesigns.org/id58.html
Glass is a kind of optical filter letting visible wavelengths through while rejecting longer IR wavelengths.
Offline xykotik
  • DonkeyTailWX DW6891
  • I'll deal with it tomorrow
    • DonkeyTail Weather
« Reply #7 on: December 30, 2011, 10:07:38 PM »
A window or glass looks a lot like WeatherHost's lexan dome.  I tried mine through a window at a steep angle for a while, but that was not a solution.  Mine is currently mounted under the eaves on the porch with no enclosure, about 30cm back from the gutter/dripline.  It has never gotten wet and we had some driving rains the last few days.  Astak Mole, which is probably the same weather-tolerance as the Foscam.
Apparently, moths like IR light as much as visible light, because in the summer they are constantly tripping the motion detection by flying into the camera.  But I also catch the occasional spider winning a midnight snack.
Facit solem suum oriri super bonos et malos et pluit super iustos et iniustos.
Springtime in Seattle...  March comes in like a lion and out like a wet lion.
Offline xykotik
« Reply #8 on: December 30, 2011, 10:10:40 PM »
But can Superman see through leaded glass, like in an xray lab?  It's one of those paradoxes for the ages.
Offline Axelvold
« Reply #9 on: December 31, 2011, 07:11:55 AM »
Then one can ask the question, why put an IR cam in a glass dome when it does not work with the IR light on?
Lars Magnusson
Axelvold / Sweden
Offline WeatherHost
« Reply #10 on: December 31, 2011, 07:34:42 AM »
^^Gotta protect the camera from the weather.  The one I have isn't intended for outside.  I haven't found anything else that will pan and tilt for a reasonable price.
Offline Axelvold
« Reply #11 on: January 08, 2012, 08:14:27 AM »
That I could understand, but why have it outside in a glassdome at night when it's no good.
But maybe there is some glassdome that don't reflect the IR light?
Lars Magnusson
Axelvold / Sweden
Offline WeatherHost
« Reply #12 on: January 08, 2012, 08:36:49 AM »
I'll just kill the IRs.  They wouldn't be effective in my case anyways due to their limited range.  IRs are only good for about 30 feet or so and my camera will be higher than that.
Offline therock64
    • St. John's Newfoundland Weather
« Reply #13 on: January 10, 2012, 01:08:30 PM »
You are all correct. IR will not penetrate glass, it has to do with the wavelengh of the IR light. You can get special glass that IR will pass but it is very expensive. I sell them in my day job for electrical switch gear. They use IR cameras to measure heat build up on connections to detect shorts or overloading. Normal glass will act as a reflector / mirror.
Also you have to understand there IS a distance that IR light will travel. You ever take a picture with a normal camera and the flash goes off, everything near to you has the flash light, but as you go pass it will get dark. Same principle... So I would say turn off the IR... Just my 2 cents worth to this.  :lol:
Gary Woodman
St. John's, NF Canada
Davis VP2 6152 wireless
Weather from "DA ROCK"
Offline mackbig
« Reply #14 on: January 10, 2012, 02:43:00 PM »
Lars,
Check out this link for some pics of my experience with an IP camera with IR LED's.
http://www.wxforum.net/index.php?topic=3931.msg34487#msg34487
A year later, the manu put out firmware to turn off the LED's, but when I first asked, they were like "why would you want to turn them off, no one would, its a day/night camera"
The only way to properly do IR assist on a night vision camera is to have the IR emitters on the outside of the glass the camera is shooting through.  The problem isnt really IR penetrating the glass, its the bounce back reflection which floods the low light capabilities of the night vision mode on the camera...
Andrew
ps: I attached an image of a q see security camera,  the black ring around the lense, prevents any reflection from the IR's which are technically behind the same glass, but cant reflect into image sensor.
« Last Edit: January 10, 2012, 02:45:34 PM by mackbig »
Offline Axelvold
« Reply #15 on: January 10, 2012, 03:39:29 PM »
I will get my cameras tomorrow, it's gonna be very intresting to see how it will be.
Just a idea, if the camera don't point direct towards the glass how would that effect the IR light?
Lars Magnusson
Axelvold / Sweden
Offline mackbig
« Reply #16 on: January 10, 2012, 04:06:09 PM »
I still think you will see the glow.  Just for regular reflection its a good idea to angle.   Are you putting inside behind a window, or actual enclosure.
Backstopping with black cloth is a good way to make the image better.
Just with hall lights, and random lights in my two camera rooms, without the blackbackground, you get some odd images due to reflection.
Andrew
Offline Axelvold
« Reply #17 on: January 10, 2012, 04:09:36 PM »
Andrew
I will put it inside behind a window, and there will be no backlight where I will put it.
Lars Magnusson
Axelvold / Sweden
Offline Dr Obbins
« Reply #18 on: January 10, 2012, 08:04:07 PM »
I just installed this IR camera last weekend with a night distance of 30 meters. Before  mounting it, I tried different locations outside on the front porch. Even when it was 2 inches from the white railing, enough IR light was reflected to cause a glare on that side of the image. Attached is a picture after it was finally mounted.
Offline Axelvold
« Reply #19 on: January 15, 2012, 12:48:18 PM »
Done some experimenting with the IR light.
Before:
And the did I make a cover for the IR light
The result with the cover on
And this is the result when it's dark outside.
« Last Edit: January 15, 2012, 12:55:22 PM by Axelvold »
Lars Magnusson
Axelvold / Sweden
Offline WeatherHost
« Reply #20 on: January 15, 2012, 03:02:35 PM »
That's basically the same idea I have, but I'm using a thick black tape/membrane as a mask.
Offline billunger
« Reply #21 on: January 16, 2012, 07:29:51 AM »
That cam takes nice pictures - what kind is it?
Offline Axelvold
« Reply #22 on: January 16, 2012, 07:36:05 AM »
It's this model, http://www.easynp.com/ShowProducts.asp?id=436
Lars Magnusson
Axelvold / Sweden
