Anybody else noticed about the WUGraphs script not working since the WU Site upgrade, WUHistory works fine. Check my site under the graphs page and see what I mean. All it does is display a small menu, then another larger menu on a new page, then a page not found error.
Any clues or ET on update to script ?
Thanks for any assistance as ever.
Nick.
The WU changes do not affect this script of the WU history pages (so far).
You can check the javascript errors by "inspect"-ing the offending page, example: right click in Chrome and choose inspect.
Uncaught TypeError: undefined is not a function dw7240.com/Base-Canada/wxwugraphs.php:145
It is little bit difficult to debug your page as the original "stand-alone" script is missing from the download. But one can call each graph on its own:
http://dw7240.com/Base-Canada/wxwugraphs/graphm1a.phpand then select all graphs from the drop-down menu and they all work as advertised.
So the error is NOT in the wxwugraphs but in the code on the page for the Saratoga template.
Probably a missing $(document).ready or another missing javascript.
Succes, Wim
PS These errors should also be removed:
Failed to load resource: the server responded with a status of 404 (Not Found) http://dw7240.com/Base-Canada/mp/audio-player3.js
Failed to load resource: the server responded with a status of 404 (Not Found) http://dw7240.com/realtime.txt
GET http://dw7240.com/realtime.txt?1403248825450 404 (Not Found) ajaxCUwx.js:948
The realtime text and the ajax cu javascript is continuasly loaded every 3 seconds? but never found
