Weather Station Hardware => Ambient Weather and Ecowitt and other Fine Offset clones => Topic started by: MrM1 on October 30, 2018, 05:15:22 PM
Does Ambient Weather make a Battery Based Display that will work with the New Osprey Array (WS-2902a type) or for the WS-1400 series array or the ObserverIP? I am needed a replacement clock on a wall, but do not want to run a power chord and wall wart off of it.
OK never mind, After reading the manual, I see that the WS-2902a-Console does accept 3 AAA batteries. I have about talked myself into the 2902a over the 2000 because (at least according to what I can find), the 2902a will connect to WeatherCloud, the 2000 will not.
The WS-2902a will not run wifi when on batteries only. Also the display will go into sleep mode (no back light) and will need a button press for it to come on for 15 seconds.
As of now the WS-2000 can be connected to WeatherCloud. You can use the same awnet app for both the WS-2902a and WS-2000 displays for setting up WeatherCloud.
My WS-2000 on Weather Cloud
https://app.weathercloud.net/d0004340656#profile
