Author Topic: NWS-Alerts map problem  (Read 559 times)
Offline rrrick8
    • Vermilion weather
« on: August 13, 2019, 12:42:02 AM »
Started implementing the new Leaflet Map NWS-Alerts script but I am having a problem fixing a map display problem.
The script seems to be working fine except when the map displays during an alert, it is all over the page with tiles everywhere even over the details text.
Then it may display the polygon over the text as well. Like it's repeating itself and has no boundaries to stay within.
Never had any problems running the older Curly script. Of course I don't use the Saratoga Template, I use Stand Alone version.
Only thing I really modified from the downloaded script was background color and table widths. Added a couple hundred px to most of the tables. I must be missing something.
Anyway, this is what it looks like with an active alert...
<?php
#   NWS Public Alerts
#   Detail Page
#   This file is to be included in another page
// Version: 1.02  12-May-2014 - Removed cookie control. Added map options
// Version: 1.03  21-Dec-2015 - Add month and day to effective & expire times
// Version: 1.04  03-Aug-2016 - Add Google Maps API
// Version: 1.05  27-Jan-2018 - Fix for PHP 7.1
// Version  1.06  14-May-2019 - replaced Google Map with Leaflet/OpenStreetMaps
// Version  1.07  15-May-2019 - fix validation errata
$Version "nws-alerts-details-inc.php - V1.07 - 15-May-2019"
//ini_set('display_errors', 1);
//error_reporting(E_ALL);
include('nws-alerts-config.php');        // include the config/settings file
// overrides from Settings.php if available
global $SITE;
if(isset(
$SITE['cacheFileDir'])) {$cacheFileDir $SITE['cacheFileDir'];}
if(isset(
$SITE['mapboxAPIkey'])) {$mapboxAPIkey $SITE['mapboxAPIkey'];}
if(isset (
$SITE['tz']))          {$ourTZ $SITE['tz'];}
if(!
function_exists('date_default_timezone_set')) {
putenv("TZ=" $ourTZ);
} else {
date_default_timezone_set("$ourTZ");
include(
$cacheFileDir.$cacheFileName);// include the data cache file
// IF config file has not been updated, do not display the map
if(!isset($displaymap)) {$displaymap '0';}
$alertDetails '';                    // set variable
$nothing      '';                    // set variable
$loclatlon    = array();               // set variable
$sfll         = array();               // set variable
$zcll         '';                    // set variable
$jsmap        '';                    // set variable
$gmjs         '';                    // set variable
$zCode        '';                    // set variable
$zCoord       '';                    // set variable
$czCode       '';                    // set variable
$asf          = array();               // set variable
$polyLegend   '';                    // set variable
$sfllarea     = array();               // set variable
// get last modified time of the cache file
$fileUpdated  date("D, n/j g:ia",filemtime($cacheFileDir.$cacheFileName));
if(isset(
$_GET['a']) && !empty($_GET['a'])) {                                  // IF the location code is set
$czCode htmlspecialchars(strip_tags($_GET['a']));                          //   clean up location code
(preg_match("/$czCode/"$validCodes)) ? $czCode $czCode $czCode ''//   set variable to location code
(preg_match("/\w{2}Z\d/"$czCode)) ? $zCode $czCode $zCode '';      //   check for zone code
if(!isset(
$_GET['a']) or $czCode == '') {                                      // IF the location code is set or no code found
$thisLoc 'an unknown location';                                            //   set location to unknown
$czCode '';        //   clear variable
$nothing 'Location has not been identified';                               //   set alert remark
if(!empty(
$noAlerts) and in_array($czCode,$noAlerts)) {                        // IF there are no alerts for current location and code is in no alert array
$thisLoc array_search($czCode,$noAlerts);                                  //   set variable to location
$nothing 'No severe weather expected for '.$thisLoc;                       //   set alert remark
// check if display map is requested
if(!preg_match('/0|1/'$displaymap)){                  // IF the map display type variable is not valid
$displaymap '0';                                    //  don't display the map
echo '<!-- $displaymap is set incorrectly -->'."\n";  //  display remark
echo "<!-- The Map is not displaying -->\n";   //  display remark
if(
$nothing <> '') {                                                           // IF there are no alerts, or missing location, create alert table
$alertDetails '
<div style="width: 830px; margin: 0px auto 6px auto; border: 1px solid #000; background-color:#00000">
 <table width="800" border="0" cellspacing="0" cellpadding="0" style="margin: 10px auto 14px auto">
  <tr>
   <td style="text-align:center; color:lime; font-size:14px; padding:4px 0px 2px;">'
.$nothing.'</td>
  </tr>
 </table>
</div>
<p> </p>
if(!empty(
$czCode)) {        // IF there are alerts for the location
foreach($atomAlerts[$czCode] as $aak => $aav) {                                               //   FOR EACH alert
$thisLoc $aav[12];        //     get the location
$aav[7] = htmlspecialchars($aav[7]);                                                        //     change html characters
$aav[8] = htmlspecialchars($aav[8]);                                                        //     change html characters
(!empty($aav[4])) ? $effective date("D, n/j g:ia",$aav[4]) : $effective '';            //     get effective time
(!empty($aav[2])) ? $intensity $aav[2] : $intensity ' - - -';                           //     get intensity
(!empty($aav[1])) ? $urgency $aav[1] : $urgency ' - - -';                               //     get urgency
(!empty($aav[5])) ? $expires date("D, n/j g:ia",$aav[5]) : $expires '';                //     get expiration time
(!empty($aav[3])) ? $certainty $aav[3] : $certainty ' - - -';                           //     get certainty
(!empty($aav[6])) ? $areas $aav[6] : $areas '';                                         //     get areas affected
(!empty($aav[7])) ? $instruction "<br />\n<b>Information:</b>\n"
.'<pre style="white-space:pre-wrap">'
.$aav[7].'</pre>' $instruction '';                   //     get information/instructions
(!empty($aav[8])) ? $details "\n<b>Details:</b>\n".'<pre style="white-space:pre-wrap">'
.$aav[8].'</pre>' $details '';                           //     get details
(!empty($aav[15])) ? $sf $aav[15] : $sf '';                                             //     get shape area
if(!empty($sf)){        //     IF there is a shape area
$sfll[] = explode(' '$sf);                                                              //       create array of coordinates for shape files
$asf[] = preg_replace("/\s/"'&nbsp;'$aav[0]);                                         //       create array for alert shape file
$sfllarea[] = $areas;
    if(!empty(
$intensity) and $intensity == 'Extreme') {
$intensity '<span style="color: red"><b> &nbsp;'.$intensity.'&nbsp; </b></span>';}      //     change intensity color
if(!empty($intensity) and $intensity == 'Severe') {
$intensity '<span style="color: #F66"><b> &nbsp;'.$intensity.'&nbsp; </b></span>';}     //     change intensity color
if(!empty($intensity) and $intensity == 'Moderate') {
$intensity '<span style="color: #B77"><b> &nbsp;'.$intensity.'&nbsp;</b> </span>';}     //     change intensity color
if(!empty($areas)) {$areas preg_replace('/;/',' -',$areas);}                              //     change semi-colon to a dash
($displaymap != '1') ? $goto '<a name="WA'.$aav[13].'" id="WA'.$aav[13].'"></a>' :
$goto '';                                                          //     remove page link if map is displayed
    // put together all details
$alertDetails .= ' <div style="width:830px; margin:0px auto 0px auto; border:1px solid '
.$aav[9].'; background-color:#171717">'.
$goto.'
  <table width="810px" border="0" cellspacing="0" cellpadding="0" style="margin:10px auto 14px auto">
   <tr>
    <td colspan="3" style="text-align:center; color:'
.$aav[9].'; padding:4px 0px 2px; font-size:110%">'
.$aav[10].'&nbsp;&nbsp;<b>'.strtoupper($aav[0]).'</b>&nbsp;&nbsp;'.$aav[10].'</td>
   </tr>
   <tr>
    <td colspan="3" style="text-align:center; letter-spacing:2px; padding:4px 8px 4px 8px; font-size:115%"><b>'
.strtoupper($aav[12]).'</b></td>
   </tr>
   <tr>
    <td colspan="3" style="text-align: center; padding:4px 12px 18px 12px"><hr style="color:'
.$aav[9].'"/><b>Areas Affected:</b><br /> '.$areas.'</td>
   </tr>
   <tr>
    <td style="padding-left:28px;"><b>Effective:</b> '
.$effective.'</td>
    <td style="padding-left:28px;"><b>Updated:</b> '
.$fileUpdated.'</td>
    <td style="padding-left:28px;"><b>Urgency:</b> '
.$urgency.'</td>
   </tr>
   <tr>
    <td style="padding-left:28px;"><b>Expires:</b> '
.$expires.'</td>
    <td style="padding-left:28px;"><b>Severity:</b> '
.$intensity.'</td>
    <td style="padding-left:28px;"><b>Certainty:</b> '
.$certainty.'</td>
   </tr>
   <tr>
    <td colspan="3" style="text-align: center; padding:4px 12px 0px 12px"><hr style="color:'
.$aav[9].'"/>&nbsp;</td>
   </tr>
   <tr>
    <td colspan="3" style="background-color: #000000; font-size:14px; padding:10px; border: 1px solid '
.$aav[9].'">'.$details.$instruction.'</td>
   </tr>
  </table>
 </div>
 <p> </p>
//echo "<!-- displaymap='$displaymap' sfll='".print_r($sfll,true)."' zCode='$zCode'-->\n";
// MAP
// create the map
$leafletScript '';
if((
$displaymap == '1' and !empty($sfll))) {                                            // IF display map option is selected & polygon provided
if(file_exists('nws-all-zones-inc.php') && !empty($zCode) && $displaymap !== '0') {       //  IF the shape file
  include_once('nws-all-zones-inc.php');  // load our Zones=>lat/lon centroid lookup table
if(isset($loclatlon[$zCode])) {
list($lat,$lon) = explode('|',$loclatlon[$zCode]);                                                 //   IF the zone code is in the shape file array
$zcll $lat.','.$lon;                                                            //     get zone code latitude,longitude
      // set polygon overlays
if(!empty($sfll)) {        //  IF there are shape files
$cp count($sfll)*4+1;        //   count shapes files, times by 4 & add - used for different line widths
$polyLegend ' <div style="width: 830px; text-align:center; background-color:#FFF">'//   create the polygon legend
$zcllA preg_replace("/(.*)\,(.*)/"'[${1},${2}]'$zcll);                //   create center location formatted output from coordinates
foreach($sfll as $zk => $zv) {                                                         //   FOR EACH shape file
$cs preg_replace("/(.*)\,(.*)/"'[${1},${2}]'$zv);                   //     create formatted polygon coordinates
$cp $cp/2;        //     divide number of shape files by 2
if($cp 1.0) {$cp 1;}
if($cp 5.0) {$cp 5;}
$czc count($zv);        //     format polygon coordinates
      $zCoord .= over_layB($zk,$cp,$cs,$asf,$sfllarea);
// create polygon legend
$polyLegend .= '
  &nbsp; <span style="white-space: nowrap"><span style="color:black; font-size:75%; background-color:'
.$rc
.'; border:1px solid black;">&nbsp;&nbsp;&nbsp;&nbsp;</span>
  <span style="color:black; font-size:75%;">'
.$asf[$zk].' &nbsp;&nbsp;&nbsp;</span></span> &nbsp;';
$zCoord .= "\n// ]]>\n</script>\n";
$polyLegend .= "\n </div>\n";
// put together google map javascript
list($mapslist,$selectedmap) = make_map_selector ($mapProvider,$mapboxAPIkey);
$gmjs .= '
<div id="map" style="width: 830px; height: 400px; border:1px solid black"></div>
<!-- Leaflet 1.0.3 javascript by Saratoga-weather.org -->
<script type="text/javascript">
// <![CDATA[
.$mapslist.'
var map = L.map(\'map\', {
center: new L.latLng('
.$zcllA.'),
zoom: '
.$zoomLevel.',
layers: ['
.$selectedmap.'],
scrollWheelZoom: false
  L.control.scale().addTo(map);
  L.control.layers(baseLayers).addTo(map);
$leafletScript '<script src="https://cdnjs.cloudflare.com/ajax/libs/leaflet/1.0.3/leaflet.js" type="text/javascript"></script>'."\n";
// FUNCTION - set google map polygon attributes
function over_layB($se,$pc,$po,$title,$affected) {
  global
$rc$atomAlerts;
$cs $se;
$colors = array('#DF0101','#F79F81','#F2F5A9','#0174DF','#58FAD0',
'#FACC2E','#01DF01','#F7BE81','#FE2E64','#E0F8EC');
$cc count($colors);
  if(!isset(
$colors[$cs])) {$tr range(0,$cs); shuffle($tr); $cs $tr[0];}
$rc $colors[$cs];
$ol =  "\n var polyc".$se." = [\n";
  foreach(
$po as $pk => $pv) {
$ol .=  "  ".$pv.",\n";
//$affected = isset($atomAlerts[$se][6])?'<br/>'.trim($atomAlerts[$se][6]):'';
$ol .= ' ];
// $asf[$se]="'
.$title[$se].'"
// $sfllarea[$se]="'
.$affected[$se].'"
 var mapoly'
.$se.' = new L.polygon(polyc'.$se.',{
  opacity: 1.0,
  color: "'
.$rc.'",
  strokeOpacity: 0.9,
  weight: '
.$pc.',
  fillColor: "'
.$colors[$cs].'",
  fillOpacity: 0.20,
title: "'
.$title[$se].'"
 }).addTo(map);'
."\n" '
  mapoly'
.$se.'.bindTooltip("'.$title[$se].'<br/>'.trim($affected[$se]).'",
   { sticky: true,
     direction: "auto"
  return
$ol;
// end of function
function make_map_selector ($mapProvider,$mapboxAPIkey) {
$output '';
// table of available map tile providers
$mapTileProviders = array(
'OSM' => array(
   'name' => 'Street',
   'URL' =>'https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png',
 'attrib' => '&copy; <a href="https://www.openstreetmap.org/copyright">OpenStreetMap</a> contributors, Points &copy 2012 LINZ',
 'maxzoom' => 18
'Wikimedia' => array(
  'name' => 'Street2',
'URL' =>'https://maps.wikimedia.org/osm-intl/{z}/{x}/{y}.png',
  'attrib' =>  '<a href="https://wikimediafoundation.org/wiki/Maps_Terms_of_Use">Wikimedia</a>',
  'maxzoom' =>  18
'Esri_WorldTopoMap' =>  array(
  'name' => 'Terrain',
'URL' => 'https://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer/tile/{z}/{y}/{x}',
  'attrib' =>  'Tiles &copy; <a href="https://www.esri.com/en-us/home" title="Sources: Esri, DeLorme, NAVTEQ, TomTom, Intermap, iPC, USGS, FAO, NPS, NRCAN, GeoBase, Kadaster NL, Ordnance Survey, Esri Japan, METI, Esri China (Hong Kong), and the GIS User Community">Esri</a>',
  'maxzoom' =>  18
'Terrain' => array(
   'name' => 'Terrain2',
 'URL' =>'http://{s}.tile.stamen.com/terrain/{z}/{x}/{y}.jpg',
 'attrib' => '<a href="https://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> <a href="https://stamen.com">Stamen.com</a> | Data &copy; <a href="https://www.openstreetmap.org/copyright">OpenStreetMap</a> contributors.',
 'maxzoom' => 14
'OpenTopo' => array(
   'name' => 'Topo',
 'URL' =>'https://{s}.tile.opentopomap.org/{z}/{x}/{y}.png',
 'attrib' => ' &copy; <a href="https://opentopomap.org/">OpenTopoMap</a> (<a href="https://creativecommons.org/licenses/by-sa/3.0/">CC-BY-SA</a>) | Data &copy; <a href="https://www.openstreetmap.org/copyright">OpenStreetMap</a> contributors.',
 'maxzoom' => 15
'MapboxTer' => array(
   'name' => 'Terrain3',
 'URL' =>'https://api.mapbox.com/styles/v1/mapbox/outdoors-v10/tiles/256/{z}/{x}/{y}?access_token='.
 $mapboxAPIkey,
 'attrib' => '&copy; <a href="https://mapbox.com">MapBox.com</a> | Data &copy; <a href="https://www.openstreetmap.org/copyright">OpenStreetMap</a> contributors.',
 'maxzoom' => 18
'MapboxSat' => array(
   'name' => 'Satellite',
 'URL' =>'https://api.mapbox.com/styles/v1/mapbox/satellite-streets-v10/tiles/256/{z}/{x}/{y}?access_token='.
 $mapboxAPIkey,
 'maxzoom' => 18
 if(isset(
$mapTileProviders[$mapProvider]) ) {
$output .= "// using \$mapProvider = '$mapProvider' as default map tiles.\n";
} else {
$output .= "// invalid \$mapProvider = '$mapProvider' - using OSM for map tiles instead. -->\n";
$mapProvider 'OSM';
$mapTilesAttrib ' | Script by <a href="https://saratoga-weather.org/scripts-quake.php#quakePHP">Saratoga-weather.org</a>';
$mList '';
$mFirstMap '';
$mSelMap '';
$swxAttrib ' | Map Script by <a href="https://saratoga-weather.org/">Saratoga-weather.org</a>';
$mScheme $_SERVER['SERVER_PORT']==443?'https':'http';
foreach ($mapTileProviders as $n => $M ) {
$name $M['name'];
$vname 'M'.strtolower($name);
if(empty($mFirstMap)) {$mFirstMap $vname; }  // default map is first in list
if(strpos($n,'Mapbox') !== false and
   strpos($mapboxAPIkey,'-API-key-') !== false) {
 $mList .= "\n".'// skipping Mapbox - '.$name.' since $mapboxAPIkey is not set'."\n\n"
 continue;
if($mScheme == 'https' and parse_url($M['URL'],PHP_URL_SCHEME) == 'http') {
$mList .= "\n".'// skipping '.$name.' due to http only map tile link while our page is https'."\n\n";
continue;
if($mapProvider == $n) {$mSelMap $vname;}
$mList .= 'var '.$vname.' = L.tileLayer(\''.$M['URL'].'\', {
maxZoom: '
.$M['maxzoom'].',
attribution: \''
.$M['attrib'].$swxAttrib.'\'
$mOpts[$name] = $vname;
$output .= "// Map tile providers:\n";
$output .= $mList;
$output .= "// end of map tile providers\n\n";
$output .= "var baseLayers = {\n";
$mtemp '';
foreach ($mOpts as $n => $v) {
$mtemp .= '  "'.$n.'": '.$v.",\n";
$mtemp substr($mtemp,0,strlen($mtemp)-2)."\n";
$output .= $mtemp;
$output .= "}; \n";
if(empty($mSelMap)) {$mSelMap $mFirstMap;}
// end Generate map tile options
return(array($output,$mSelMap));
<div style="width:832px; margin:0px auto 0px auto;">
 <table cellspacing="0" cellpadding="0" style="width:100%; margin:0px auto 0px auto; border:1px solid black; background-color:#000000">
  <tr>
   <td style="text-align:center; background:url(<?php
echo $icons_folder ?>
/NOAAlogo1.png) no-repeat; background-position:center; padding:5px 0px 5px 0px"><h3>Weather Alerts for <?php
echo $thisLoc?>
</h3><p>Issued by the National Weather Service </p></td>
  </tr>
 </table>
 <p> </p>
<?php
echo $leafletScript;
echo
$gmjs;
echo
$zCoord;
echo
$polyLegend
 <p> </p>
<?php echo $alertDetails ?>
</div>
Severe Weather Manager-Vermilion County EMA
CWOP-CW9931 KILDANVI5
Offline tmabell
    • Mishawaka Weather
Re: NWS-Alerts map problem
« Reply #1 on: August 13, 2019, 05:58:53 AM »
Looks like you are missing a required style sheet (NWS-forecast-map.css)
Offline rrrick8
    • Vermilion weather
« Reply #2 on: August 13, 2019, 07:39:25 AM »
Thanks for the reply... I uploaded it with all the other items in the zip package. It is there in the same directory as the others.
I can't find where it is called anywhere by the scripts like I thought it should be. Added to my header and tested by adding a county with active alert and it appears to be working fine now.
Thanks.
