I have been fighting this problem since early January and have not been able to beat it thus far.
The problem is my greeting display is not working and it gets better. When the page is first loaded it briefly shows the data from the last time the greeting worked.
All this started when I had to replace the hard drive in my computer and in the process of doing so, I decided to update a bit and go from XP the WIN 7. All this required building from scratch with a new motherboard and all. After all, was installed and Weather Display was installed again using the backup procedure which failed is where all the fun begins. I Was able to get the settings from the old HDD using lots of time Anyway, I have apparently missed something but I have gone over the setup many, many times. I'm open to any suggestions. It shows up when the page is loaded https://www.smythweather.net Thanks for any help with this.
Wt
testtags.php :The contents or the file itself is old, from Jan 6, 2019
https://www.smythweather.net/testtags.php?sce=viewThe website-scripts first display the data from testtags.php which is the old data.
The correct data comes a few seconds later from javascript which uses clientraw data to update the realtime values only.
Probable causes you should check on your PC:
1. WD is generating a testtags.php but not uploading it, 20% chance
2. WD is generating and uploading but the testtags.txt is invalid, it contains data not tags, 70% chance
3. WD is not allowed to upload the new testtags.php because of permissions on the server, 9%
4. Other ??
Also: some key scripts which are used to find and inspect are missing (wxstatus.php) or old (check-fetch-times.php)
F.i. I can see the contents of the testtags.php using sce=view
But if wxstatus.php was available, you yourself and people who try to help you, can inspect the timestamp of the file to check when it is uploaded.
Success, Wim
