Author Topic: Sun/Moon Data  (Read 1540 times)
Offline griffo42
    • Carina Weather
Sun/Moon Data
« on: April 11, 2019, 07:25:13 AM »
Hi from Brisbane Australia
I would like to include the Sun/Moon data from Andreas Hörstemeier on my site just as merc92 has done.  I have downloaded Andreas' moontool.zip and moon20.zip and unzipped them into separate folders but don't know where to go from there.  I am running Win 10 software.
Hope to hear from a helper soon
Thanks in advance
Keith
https://www.kstwx.net/index.php
Davis Vantage Pro2 Model #6152AU
Cumulus latest version
Saratoga Weather World template Cumulus plugin
Carina Weather, Brisbane.
Re: Sun/Moon Data
« Reply #1 on: April 11, 2019, 04:27:23 PM »
Do you mean the downloads from http://www.hoerstemeier.com/moon.htm ?
These are neither website (PHP) nor AJAX (JavaScript) programs.. they are written in Delphi (a TurboPascal derivative) and display stuff in a window on your PC (AFAIK).
You don't need the TMoon download -- it just contains the Delphi source code in case you wanted to compile it yourself.
The moontool.zip contains Windows setup.exe file which would install the application on your system.  However, trying to run that SETUP.EXE (1999 date) is refused by Windows 10 (on my system), likely because it isn't signed code, so is prevented from running.
I suggest you abandon that app .. It likely only runs on Windows XP/7/Vista and not on Windows10
Offline griffo42
    • Carina Weather
Re: Sun/Moon Data
« Reply #2 on: April 11, 2019, 04:47:12 PM »
Hi Ken
Thanks for your advice, expert as always!
That project is now abandoned.
Keith G
Offline WeatherHost
Re: Sun/Moon Data
« Reply #3 on: April 11, 2019, 07:24:16 PM »
You might look at timeanddate.com to see if they have anything you could use.
