Interesting. That's along the lines of what I would like to do. FARS/75 for temp and dewpoint in a separate passive.
The only caveat is that I wanted to provide light supplemental heat inside of the passive shield to prevent the SHTxx from ever approaching condensation. I'd use the dewpoint from that and the temp from my FARS to calculate a new RH to send to CWOP.
I know Brian from WD is pretty flexible with his customers so maybe he could make an update for me with that option.
Not to jump into your thread with my own question, but is it possible to add a small resistor to the temp/hum voltage line to provide a little heat? I figure the sensor is getting a steady supply of voltage so the current will change. All I really need is enough heat to keep a dewpoint depression of at least 5F (80% RH). Where I live, if there's wind, usually it's accompanied with drier air anyway. So during those high RH times (precip or rad cooling) the wind is usually light and the supplemental heat should do its job. Maybe a resistor that will put out 5-10W? What does the voltage to the sensor usually run at? ~3V?
Again, not trying to steal your thread. It's just running tangent to the ideas I have in my head right now. Nice find though. I may have to pony up for WD. I just wish I could get 0.1F resolution with the 2nd sensor.
