I have the same unit. The fan aspiration is really only critical when you have high solar radiation in a breeze free environment. As you mentioned, you are not getting enough solar radiation to power your fan. Therefore, the solar radiation is probably not enough to influence your readings. Although there are additional radiation shields on your unit, the unit should function fine as a "passive" radiation shield, allowing plenty of airflow. These shields will not insulate the sensors, other than from solar influence. I am in a valley, with very few other PWS's nearby with similar topography. This morning I registered a low temp of 16 deg. F. Using "Weather Exchange", I could see I registered the coldest temp in a 30 mile radius. Therefore, I don't believe the shielding is preventing accurate sampling of the ambient temperatures/humidity levels.
