Dear WXForum Davis experts,
I'm switching my weather station from solar to AC power and while I'm at it, I've bought the Davis 7747 kits to provide a fan for my temperature/humidity probe. However, I want to power that motor using an AC adapter as well. I checked the output of the solar panel intended to power the motor, and it appears to out put about the same 2.5 Volts as the solar panel powering the ISS (the solar panels appear to be identical in fact.)
Unfortunately, 2.5 Volt AC adapters appear to be a bit rare. 1.5 Volt and 3 Volts adapters are plentiful. Does anybody know what are the actual voltage and current requirements for this motor? Davis does sell the replacement motor as part number 7758. This should not be confused with the Davis 7758B kit which is a motor plus batteries for the FARS stations. I suppose I should also ask, does anybody know if the motor is the same for both systems?
By the way, there is a review for the Davis replacement motor on Amazon that claims you can buy these motors cheaply from Chinese electronic supply houses:
http://www.amazon.com/review/R2X8WPYODT3ONA/ref=cm_cr_pr_perm?ie=UTF8&ASIN=B004XBI4DMDoes anybody know anything about that?
Cheers, Edouard
