Weather Station Hardware => Ambient Weather and Ecowitt and other Fine Offset clones => Topic started by: dman7800 on March 18, 2012, 03:36:59 PM
Title: WS1090 and added the SRS100LX
Post by: dman7800 on March 18, 2012, 03:36:59 PM
Hey all, I had a question for everyone.  Just got my WS1090 and added the SRS100LX.  I have attached a picture as it describes a million words.
My question is this.  Am I better off leaving the thermo-hydro transmitter with the shield on the pole or under the eve of the garage?  My temps seem to be running a degree or two higher than the area.
Title: Re: WS1090 and added the SRS100LX
Post by: SlowModem on March 18, 2012, 05:40:03 PM
Leave it there for a week and compare to the area.  Then move it to the other place for a week and compare.  I had holes all in my yard from where I moved sensors around when I first got mine.  :)  But you have to give it time and see what the average is.
Post by: DanS on March 18, 2012, 07:13:12 PM
Is there an option for "plan C", thermo/hygro sensor away from the house completely and out in the open over a grassy area? (see:   http://www.nws.noaa.gov/om/coop/standard.htm )
That shield upgrade was a good move on your part.
Besides NWS recommended guidelines stating this for siting, I have 2 stations running and one (D4009) is placed close as I can find to this suggested location. About 1/2 mile down the road is an airport METAR reporting station (VTCC) that I compare to. For a test I first set both of my stations out over the grass to get an idea how they would measure (1st pic). Now I have one of my stations under the eave on the north side of the house (D2642, second pic). You can see where the mid-day and afternoon sun that warms the ground below the "out-in-the-open" location is missed by mounting under the eave and out of the sun.
Post by: dman7800 on March 18, 2012, 11:10:04 PM
Yeah, in the summer the north side its on does stay shady.  I may just stick it under the eve next weekend.  I did notice I was on track with some in the area, some same and some 4 degrees cooler.
My yard is big but does go down to a natural swail which goes approx 6' below the house foundation so I was worried the winds wouldn't register right.  The height here is about 6' above roof lines.
Post by: Stetson1 on March 29, 2012, 02:26:13 PM
Every setup is a compromise. My unit sits just under the north side eave of my house. I extended the cable for the anemometer and put it 8 feet above my roof line to get the wind correct. Is my placement perfect, no. Given my small yard and all the trees around it is the best I can do, on the upside it is within a degree of a VP2 a mile away that is placed out in the open so I decided to keep it where it is. Perfect is the enemy of good as the saying goes.
Todd
Post by: jimmy1913 on February 26, 2014, 06:37:40 PM
I painted the inside of the plate's flat black dropped my temps around 2 degrees!
