The version I have is a 5v/3.6A. It's a universal adapter, so you have to select the tip. You should bring your console in so they can match the tip so that it will fit your console. When you install the tip, you can install it for either positive or negative polarity. Your console requires positive polarity, so make sure you install it according to the included instructions, so that it is positive polarity. It's an ENERCELL 2730437 AC-to-DC Travel Charger. Hope this helps.
