I think I figured out part of the problem.
WeatherLink is operating off of VirtualVP. Calibrated setting changes don't work in TCP/IP mode. When I disconnected WeatherLink from VVP and connected directly to the console in Serial Com Port mode, I could again adjust the calibrations.
The strange thing is when I change calibration to something other than "raw" in Serial mode, and then change back to TCP/IP mode through VPP, the calibration would pop back to a reading higher than it was before. Example: the setting was 100%; it change to 105%. That obviously does not compute.
But when I keep the calibration the same as the raw setting, it reads ok.
The problem is the outdoor humidity reading is 4% points below the surrounding stations within a half mile which all read 95%. Hmmm.
Do you still think I need to create a new station? Would it still continue with the same data logger data or will that be lost?
