Hi Wim,
thank you very much! This is absolutely sufficient in terms of the units. Now if you could supply the tags that would be ideal, my email is jachymcz@gmail.com. I was trying to figure this out by looking at Kens script for updating WL, but the problem I had was that I was not able to find gust and also daily cumulative precipitation, but I might have just missed it. My last question would then be if the date/time format are fixed and if not, what can they be and if the decimal is always given by "." or if it can be "," depending on local settings.
Thanks again
Tags:What tags do you need? Do you have an "ideal" list of tags you want? This is the list I use for WL.
http://weather-template.nl/weather27/scriptsWL/tags.wl.htxDates:There is no tag in WL (as in many other programs) to specify the date format or to know what date format is used.
I made a list in the settings file for dates with
- as separator : '-' or '/' or ' '
- year with or without century dd/mm/yy dd/mm/yyyy
- the sequence d-m-y m-d-y
And when that is not suffcient one can specify the separator and the first, second and third part of the date.
# IMPORTANT How are the date/time fields formatted for your weather program.
# Important for WVIEW VWS Weatherlink
# set a comment mark for all lines which are not correct
#$my_date_format = 'mm-dd-yyyy'; # 03-15-2015 march the 15th, 2015
#$my_date_format = 'mm-dd-yy'; # 03-15-15 march the 15th, 2015 without the century 20
#$my_date_format = 'mm/dd/yyyy'; # 03/15/2015 march the 15th, 2015
#$my_date_format = 'mm/dd/yy'; # 03/15-15 march the 15th, 2015 without the century 20
#$my_date_format = 'dd/mm/yyyy'; # 15/03/15 15th of march 2015
$my_date_format = 'dd/mm/yy'; # 15/03/15 15th of march 2015 without the century 20
#$my_date_format = 'dd-mm-yyyy'; # 15-03-2015 15th march 2015
#$my_date_format = 'dd-mm-yy'; # 15-03-15 15th march 2015 without the century 20
#$my_date_format = 'other'; # set this one uncommented if none of the others is correct
# if you selected 'other' What character is used between the three date fields
# $my_char_sep = '/'; # example 12/25/2015
# $my_char_sep = '-'; # example 01-12-2014
# $my_char_sep = ' '; # example 20 3 2015
# Now we set the position of the day month and year in the date fields
# example 2015-03-15 the year is first (1) part the month is second (2) part the day is the third (3) part;
# $my_day = 1 ;
# $my_month = 2 ;
# $my_year = 3 ;
Times are releative easy, as they only differ in having am/pm or not.
Decimal Here I have no idea. I did not encounter a "decimal point=comma" with WeatherLink.
WeatherCat and Cumulus do support that, so I do a "check and replace" if there are comma's in the fields.
Wim
