Thank you, dalecoy
Answers below in red
Yes, it is expected that those two .dat files are recreated. A few questions, then:
What kind of logger are you using?
It's an IP logger connected by Ethernet cable to my router
Are you uploading to anywhere else, in addition to APRS?
No
What changed at your location/computer/network around mid-day on the 22nd? [AND is that perhaps when you uninstalled the old version and installed the new version?]
It does coincide with the uninstall and update
What was the version of Weatherlink that you were using, that had the problem?
I am not sure, maybe 5.9.something
Exactly how did you uninstall the problem version, before installing the new one?
I used Windows(10) uninstall and then I deleted the entire Weatherlink directory from the root directory This should answer the next question, too
When you uninstalled the problem system, did you delete *ALL* of the files from the configuration?
Knut - AB2TC
