Author Topic: After several days VVP keeps sending same data...  (Read 2218 times)
Offline bigdog660
« on: January 09, 2013, 10:24:34 PM »
After several days of working, my VVP seems to lock-up and keeps sending same data over and over. At the bottom of the VVP window, it complains about a file access error.
If I quit and restart VVP, the data resumes uploading until another several days to a week. It's very frustrating because I have no way of knowing when it freezes, so a day or two might go by before I realize my data is missing.
Is it possible that 1.5GB of memory (running Windows 7 on a netbook) is not enough, and perhaps the VVP data file gets switched to virtual memory? Or is this a problem with VVP? If there is no solution, is there any software out there that could alert me is no (new) data is being sent to a certain address or through a certain port?
TIA,
Ron
<img>
Offline Beaudog
Re: After several days VVP keeps sending same data...
« Reply #1 on: January 10, 2013, 09:27:24 AM »
You did not say how you were connected with VVP.       Com Port or TCPIP.
If com port try clicking the box to allow VVP to restart the data logger
Offline bigdog660
« Reply #2 on: January 11, 2013, 12:06:25 AM »
Thanks for the reply. No, I did not have the box checked to allow VVP to restart the data logger. I didn't do that since my data logger is the serial version; however, I have to use a serial to usb converter since Notebooks do not have serial ports. Is it okay to allow VVP to restart the data logger even though the actual logger is a serial port version?
Last night was a disaster, the file access error reported again only after running a hour this time. Here is the log I finally was able to remember to save:
00:00:29:444 Warning      - VpConsole: No response after several retries for Wake Up Console
00:48:01:238 Warning      - VpConsole: No response after several retries for Wake Up Console
00:48:03:438 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:48:04:810 Warning      - VpConsole: No response after several retries for Wake Up Console
00:48:06:183 Warning      - VpConsole: No response after several retries for Wake Up Console
00:48:08:367 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:48:09:740 Warning      - VpConsole: No response after several retries for Wake Up Console
00:48:11:113 Warning      - VpConsole: No response after several retries for Wake Up Console
00:48:13:312 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:48:14:685 Warning      - VpConsole: No response after several retries for Wake Up Console
00:48:16:074 Warning      - VpConsole: No response after several retries for Wake Up Console
00:48:18:273 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:48:19:646 Warning      - VpConsole: No response after several retries for Wake Up Console
00:48:19:755 Error        - VpConsole: Too many consecutive failures of console to respond. Will continue trying periodically.
00:51:25:736 Warning      - VpConsole: No response after several retries for Wake Up Console
00:51:27:935 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:51:29:324 Warning      - VpConsole: No response after several retries for Wake Up Console
00:51:31:164 Error        - File access denied
00:51:31:601 Error        - File access denied
00:51:32:038 Error        - File access denied
00:51:32:475 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:51:32:631 Error        - File access denied
00:51:32:756 Error        - File access denied
00:51:32:974 Error        - File access denied
00:51:33:192 Error        - File access denied
00:51:33:504 Error        - File access denied
00:51:33:728 Bug          - TVpCom.BeatNotify: VpConsole: Wake Up Console pkt not enabled
00:51:33:858 Warning      - VpConsole: No response after several retries for Wake Up Console
00:51:34:097 Error        - File access denied
00:51:34:214 Error        - File access denied
00:51:34:566 Error        - File access denied
00:51:35:122 Error        - File access denied
00:51:35:574 Error        - File access denied
00:51:35:918 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:51:36:120 Error        - File access denied
00:51:36:323 Error        - File access denied
00:51:36:510 Error        - File access denied
00:51:36:776 Error        - File access denied
00:51:37:041 Error        - File access denied
00:51:37:259 Bug          - TVpCom.BeatNotify: VpConsole: Wake Up Console pkt not enabled
00:51:37:368 Warning      - VpConsole: No response after several retries for Wake Up Console
00:51:37:478 Error        - File access denied
00:51:37:602 Error        - File access denied
00:51:37:930 Error        - File access denied
00:51:38:367 Error        - File access denied
00:51:38:804 Error        - File access denied
00:51:39:240 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:51:39:396 Error        - File access denied
00:51:39:521 Error        - File access denied
00:51:39:755 Error        - File access denied
00:51:39:974 Error        - File access denied
00:51:40:192 Error        - File access denied
00:51:40:520 Bug          - TVpCom.BeatNotify: VpConsole: Wake Up Console pkt not enabled
00:51:40:644 Warning      - VpConsole: No response after several retries for Wake Up Console
00:51:40:754 Error        - File access denied
00:51:40:863 Error        - File access denied
00:51:41:284 Error        - File access denied
00:51:41:721 Error        - File access denied
00:51:42:158 Error        - File access denied
00:51:42:610 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:51:42:766 Error        - File access denied
00:51:42:891 Error        - File access denied
00:51:43:109 Error        - File access denied
00:51:43:328 Error        - File access denied
00:51:43:546 Error        - File access denied
00:51:43:874 Bug          - TVpCom.BeatNotify: VpConsole: Wake Up Console pkt not enabled
00:51:43:983 Warning      - VpConsole: No response after several retries for Wake Up Console
00:51:44:108 Error        - File access denied
00:51:44:217 Error        - File access denied
00:51:44:638 Error        - File access denied
00:51:45:075 Error        - File access denied
00:51:45:527 Error        - File access denied
00:51:45:948 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
00:51:46:058 Error        - VpConsole: Too many consecutive failures of console to respond. Will continue trying periodically.
00:51:46:389 Error        - File access denied
00:52:02:982 Error        - File access denied
I disconnected (software wise) VVP and reconnected and got these errors tonight
23:10:12:668 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:13:697 Info         - Weather Display: Received Get Live Sensor Data
23:10:13:697 Info         - Weather Display: Sent response for Get Live Sensor Data
23:10:13:713 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:14:664 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:16:006 Info         - Weather Display: Received Get Live Sensor Data
23:10:16:006 Info         - Weather Display: Sent response for Get Live Sensor Data
23:10:16:022 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:16:661 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:18:315 Info         - Weather Display: Received Get Live Sensor Data
23:10:18:315 Info         - Weather Display: Sent response for Get Live Sensor Data
23:10:18:330 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:18:658 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:20:624 Info         - Weather Display: Received Get Live Sensor Data
23:10:20:624 Info         - Weather Display: Sent response for Get Live Sensor Data
23:10:20:639 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:20:655 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:22:652 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:22:932 Info         - Weather Display: Received Get Live Sensor Data
23:10:22:948 Info         - Weather Display: Sent response for Get Live Sensor Data
23:10:22:948 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:24:648 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:25:241 Info         - Weather Display: Received Get Live Sensor Data
23:10:25:241 Info         - Weather Display: Sent response for Get Live Sensor Data
23:10:25:257 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:26:645 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:27:550 Info         - Weather Display: Received Get Live Sensor Data
23:10:27:566 Info         - Weather Display: Sent response for Get Live Sensor Data
23:10:27:566 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:28:642 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:29:859 Info         - Weather Display: Received Get Live Sensor Data
23:10:29:859 Info         - Weather Display: Sent response for Get Live Sensor Data
23:10:29:874 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:30:639 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:32:168 Info         - Weather Display: Received Get Live Sensor Data
23:10:32:168 Info         - Weather Display: Sent response for Get Live Sensor Data
23:10:32:183 Info         - Couldn't serve Get Live Sensor Data, cache data too old
23:10:32:636 Info         - Couldn't serve Get Live Sensor Data, cache data too old
I have WL connected via COM ports, and WD connected via TCP 127.0.0.1:3355.
<img>
Offline katdoc
« Reply #3 on: January 15, 2013, 02:16:15 AM »
Hello
I am using vvp with cumulus and weatherlink and after some hours everything freezes.i am using tcp/ip since i tried and failed to work with vcom ports.Also i realised that vvp uses many resources.Is it normal? Can i do anything else? Some hints or tips maybe :)
Thanks in advance
Nick
Offline bigdog660
« Reply #4 on: January 25, 2013, 03:55:46 PM »
Hello
Thanks in advance
Nick
I just checked my VVP, and it uses about 3.3MB of memory which isn't bad at all. Try using Eterlogic VSPE as you vcom software. It's very easy to configure, and it's free for 32-bit Windows. Just make sure you create 2 "pairs" (one for each weather station software you run). Also make sure you delete all the old vcom drivers you may have installed before installing Eterlogic VSPE.
As for why everything freezes, I don't know. I run WeatherLink and Weather Display. I have never had a problem with WeatherLink, but several months ago, I had issues with Weather Display suddenly stop reading the data after several days. After several builds of Weather Display, the author must of fixed the problem because I don't have that problem anymore.
The last problem I had was VVP would stop reading from the weather station, and complain about "file access denied". With the help of Beaudog, I ticked the "Let VPLive restart the Davis USB data logger (only for USB data loggers)" box, and that has fixed my problem. I have been running for 8.5 days now without a hiccup.
BTW, I have WeatherLink collecting data via IP, and Weather Display via com port. Good luck Nick!
<img>
