Author Topic: wi-fi on the road  (Read 2300 times)
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
wi-fi on the road
« on: February 14, 2012, 09:07:59 PM »
How are people handling on-line security on wireless networks? Typically I will use hotel in-room wired connection, but was wondering about a vpn hotspot, or other alternatives.
Any suggestions for windows 7 user?
Ed
Offline kray1000
  • Purveyor of wry
Re: wi-fi on the road
« Reply #1 on: February 14, 2012, 09:31:33 PM »
A cell phone with mobile hotspot capability.
« Reply #2 on: February 14, 2012, 09:50:36 PM »
I have used Easytether with my android phone.
Offline mackbig
« Reply #3 on: February 15, 2012, 08:07:59 AM »
I used my blackberry tethered in Canada (US data roaming too rich for our plans).  In the states I will "trust" a Starbucks, hotel, or Airport hot spot.  Wont do any banking or anything like that.  In hotels with wired, I bring along my Apple Airport Express, then all my devices can enjoy the one connection, and then I can also use my laptop on the balcony.  My laptop will also act as a wifi spot when the hotel has a "one device" policy set-up.  My dell acts as the MAC control, so they dont know I really have 5 devices working.
Andrew
« Reply #4 on: February 15, 2012, 12:21:01 PM »
Andrew
Connectify will do the same thing.  Freeware.
Offline ed2kayak
  • Ed
« Reply #5 on: February 15, 2012, 08:56:10 PM »
OK, so I'll try my phone. What kind of battery life do you get broadcasting a wifi signal?
Ed
« Reply #6 on: February 15, 2012, 09:34:37 PM »
Terrible.  Burns fast. Have only done that a few times.
 But I am usually in a place I can keep the laptop plugged in-then it charges the phone.
Easytether uses the phone as a modem-not as a moblie hotspot.  So it has to be connected to the laptop.
should have said that earlier-  :???:
Offline mackbig
« Reply #7 on: February 16, 2012, 06:38:22 AM »
If you have to tether over USB, battery life should not be a problem as it would be charging from the laptops simultaneously.   Tethering over bluetooth does use battery, but not much in my experience.  If the screen is not on, its just using the radio (two radios).  I would think you should at least get your phone's quoted "talk time" amount while tethered by bluetooth.
Andrew
Offline kray1000
  • Purveyor of wry
« Reply #8 on: February 16, 2012, 09:31:44 AM »
For me the battery life isn't that bad, but even the manufacturer recommends using the charger when enabling the hotspot.  Or you can tether (USB), if you just have the one laptop.
