Author Topic: WS2810 with FARS installation pix.  (Read 12499 times)
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« on: December 27, 2009, 04:45:32 PM »
Just finishing up my WS2810 installation and now posting a few pictures.
Here, the FARS is being built. I found some bowls made out of a Bakelite type of material. Very dense and rigid material that doesn't flex or glow inside from sun shining on it outside. Properties like ceramic but still workable with a drill and dremel tool. Fan is a standard P.C. 12v fan and panel is a 12v 500ma unit. No battery, just comes on in the late morning and turns off in the late afternoon/evening.
The ISS and rain gauge are mounted in a location the best I could find to meet CWOP's siting guidelines. Not the best but for what I have available it's a start anyway. A lot of tree/plant trimming was done after these pictures were taken. Actually the mount is further away from the vegetation than how it appears here. The FARS is about 5 feet above grass. Rain gauge, leveled, on top right above. Pole is a 3" PVC tube filled with cement and about 3 feet in the ground. No ground freezing to worry about here. :roll:
Both (2310 and 2810) anemometers are on the same mast approximately 38 feet AGL. No obstructions in any direction. Got lucky with this part. They're both located about 20 feet from the crest off the roof and 5 feet higher.
« Last Edit: November 16, 2010, 06:13:07 PM by DanS »
    • Watts Bar Weather
Re: WS2810 with FARS installation pix.
« Reply #1 on: December 27, 2009, 04:49:06 PM »
Offline Axelvold
« Reply #2 on: December 27, 2009, 05:07:54 PM »
Very nice.  =D>
Lars Magnusson
Axelvold / Sweden
55° 57' 41" N / 13° 6' 1" E
Offline DanS
    • ThaiWx
« Reply #3 on: December 27, 2009, 05:16:35 PM »
Thanks Greg and Lars. I'll give it a couple of days to see how the ISS does in it's present location and relocate if needed. I like having something like this to do!  :grin:
Offline Anthony
    • Anthony's Weather
« Reply #4 on: December 28, 2009, 08:42:07 AM »
Where did you find that big huge solar pannel & how much did it set you back?
Anthony
WB8YUE
Offline DanS
    • ThaiWx
« Reply #5 on: December 28, 2009, 08:56:49 AM »
I mail ordered that panel from J.C. Whitney back in 1993 when was living/working in Bangkok. I would be away on assignment for weeks at a time and didn't want my car's battery back in Bangkok to die while I was away. I used it to keep a charge going on the battery. If I remember it was about $50 plus whatever the shipping was. It has no problem running a P.C. 12v fan for this application. I went out and checked this morning about 9Am, the sun was at about a 45 degree angle to the panel and the fan was running. Around 4:15Pm the sun was low enough for a shadow to cover the area and it stopped. Should be longer run times in the summer when the sun is up higher overhead.
« Last Edit: December 29, 2009, 04:58:30 AM by DanS »
Offline Anthony
    • Anthony's Weather
« Reply #6 on: December 28, 2009, 03:13:52 PM »
$50, not a bad price 16 years ago. I wonder what it costs now? And I wonder how the pannel will stand up to the elements, expecially here?
Anthony
WB8YUE
Offline DanS
    • ThaiWx
« Reply #7 on: December 28, 2009, 05:40:45 PM »
Mine looks like no problem with the elements because it's sealed in some kind of resin wrapping then put in a frame for support. If it held up this long being outside in the brutal sun, monsoons, etc. I guess it's sealed up pretty good. I did see one at J.C. Whitney that has the same specs. and about the same size but the price has kept up with the times ...
http://www.jcwhitney.com/Sunsei_Medium_Duty_Solar_Charger?ID=12;0;1101016450;0;100001;ProductName;8;0;0;0;2012891;0;0
I would imagine that the construction is designed to hold up well out in the elements. All the panels I've seen are usually sealed to a phenolic type circuit board with a clear water proof plastic resin material.
« Last Edit: December 28, 2009, 05:50:15 PM by DanS »
    • Watts Bar Weather
Offline Strgazr27
  • "The Cam Man"
    • Kings Park Weather
« Reply #9 on: December 28, 2009, 11:16:22 PM »
 =D> \:D/
Nicely done Dan. And that solar panel ROCKS!!
Bobby M.
Davis VP2 6152 w Daylight FARS - Logitech C525 and C310
WD - WDLive - GRLevel3 - Image Salsa - VVP - Startwatch
"http://www.kingsparkweather.com"
KNYKINGS7 on WU
Offline DanS
    • ThaiWx
« Reply #10 on: December 28, 2009, 11:45:33 PM »
Thanks Bobby. That panel is like a roadside billboard but it's size is being put to use as a sun blocker to the shield also. Double duty.  Now I'm doing a lot of comparing and updates with the int'l airport/Metar 1/2 mile west of here to see if this location keeps up with their readings. This morning I put a patio umbrella over the whole ISS mast to keep today's sun off the surrounding ground/grass. I will compare today's temp. graph with theirs this evening. This is just to see the difference between a shaded area and a location wide open in the sun like CWOP recommends. I noticed that even with the umbrella overhead blocking the sun that the FARS fan is still spinning from just the surrounding daylight.
« Last Edit: December 29, 2009, 12:19:07 AM by DanS »
Offline DanS
    • ThaiWx
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
« Reply #12 on: December 29, 2009, 07:37:45 AM »
Of course, they're available at Wallyworld, too.
http://www.walmart.com/catalog/product.do?product_id=10339302
http://www.walmart.com/catalog/product.do?product_id=11062009
http://www.walmart.com/catalog/product.do?product_id=10339301
I bought one of the Coleman panels from Walmart, and I found that they are NOT weather sealed, for outside use like Dan is using.  They were able to power a decent computer fan.  I returned the panel because of the lack of weather sealing and put my project on hold.  Now perhaps Dan has gave me a new source of panels. ;)
Pics of the Coleman when I had it.
Offline Anthony
    • Anthony's Weather
« Reply #13 on: December 29, 2009, 08:25:40 AM »
Thanks everyone for the links and the information. I'll bet with a 30 watt pannel I could run my whole station on it. Including the existing solar x-mirrers. All you would need is the guts from the current x-mitters and a few resistors to reduce the voltage from the main solar pannel. I'll bet theres someone here whos smart enough to figure it out. May not even need a 30 watt. Might get by with a 20 watt.
Anthony
WB8YUE
Offline DanS
    • ThaiWx
« Reply #14 on: January 24, 2010, 11:54:13 PM »
I have difficulties when running my WS2810 nearby the other WS2310 station on the same desk (interference) so I constructed a stand for the WS2810 to separate the two. It's an old steel (brass finish) floor fan base I painted and fabricated a small platform on top to match the station's base. Adjustable height and tilt head mount.  Looks like it belongs in a bank lobby but at least it isn't across the room anymore on a bookshelf. Thought I'd post to maybe help someone else with similar issues with any station console, limited desk space, etc.
« Last Edit: January 25, 2010, 12:10:52 AM by DanS »
Offline Strgazr27
  • "The Cam Man"
« Reply #15 on: January 25, 2010, 12:57:28 AM »
 \:D/ =D> =D>
Bobby M.
KNYKINGS7 on WU
    • Watts Bar Weather
« Reply #16 on: January 25, 2010, 03:57:02 AM »
Offline killwilly
« Reply #17 on: January 25, 2010, 04:44:08 AM »
Sadly Dan, I missed this post when it started, but your whole set-up looks very good, congrats.  =D>
Alan.
Alan
Offline DanS
    • ThaiWx
« Reply #18 on: January 25, 2010, 05:12:06 AM »
Thank you Alan. I'm still going though the learning curve with the 2810 and making adjustments/corrections as I find where they're needed but all in all happy with it.
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #19 on: January 25, 2010, 09:47:03 AM »
Nice idea....... =D>
