Hi all,
My WS-1001 is about 9 months old and in recent times the rainfall readings have been intermittent. Example: It starts raining, rainfall is initially recorded and then it stops reporting the rainfall. It seems to be sporadic, sometimes it works fine and sometimes it doesn't.
I have opened up the weather station and cleaned it out, there was nothing blocking the tipping bucket though.
I did some testing over the weekend I continuously kept tipping water in the rain gauge, it recorded for quite a while and then yes the problem did occur where it failed to record any rainfall no matter how many times I tipped more water in. I could hear the tipping bucket empty the water each time so there is definitely no problem them.
I have contacted the seller I purchased the unit from and they have suggested I replace the factory standard rechargeable batteries, with Energizer rechargeable batteries. They stated it would give the station much better results and range.
Could this actually be the cause of my intermittent rainfall recordings? All my other readings are perfect.
