Author Topic: pmopp&tp  (Read 1059 times)
Offline Cutty Sark Sailor
pmopp&tp
« on: September 07, 2017, 02:45:44 PM »
Poor Man's Odd Parts Pan & Tilt Proto...
Spouse on a 'Clean Up Your Junk' kick... had to show her "I need this stuff"...
so,....
Heh  ...  3V will drive a Hikie... now, to build a real one...
Click image to see it in action... heh...
Why? Well, ...  she said, "Prove it"... Now I get to keep my junk until the next "CUYJ" spousal crusade...
« Last Edit: September 07, 2017, 02:51:49 PM by Cutty Sark Sailor »
Offline SLOweather
    • Weatherelement Moline IL
Re: pmopp&tp
« Reply #1 on: September 07, 2017, 03:50:43 PM »
Good job!  Mebbe we shout start a PMOP project thread... Last weekend I happened across the perfect free electric motor assembly (you wouldn't believe what it's from) to rebuild my late grandfather's antique wrought iron BBQ rotisserie with a 50:1 antique Boston Gear right angle gear reduction.
If you wanna guess, here's a pic of the motor assembly, minus the flat belt. The opposite wheel is the same as the one you can see, but the cams are 180° out of phase. The motor is on a hinged mount and gravity tensions the belt.
« Last Edit: September 07, 2017, 04:13:14 PM by SLOweather »
Offline dupreezd
Re: pmopp&tp
« Reply #2 on: September 07, 2017, 04:23:24 PM »
To me it looks like it might be from an old belt massager. :-)
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
