Author Topic: Weatherlink has stopped responding  (Read 5001 times)
Offline weathergirl
    • Beamsville Weather Station
« on: January 07, 2017, 10:01:39 AM »
This morning, Weatherlink 6.0.3 has stopped responding. When I restart it, the window appears but Weatherlink doesn't download any data. I am running Windows 10 and Weatherlink is using a serial link to my computer. VVP shows that Weatherlink is connected on the comport I allotted it to. I have had no problems up to now.
Ann-Marie
Beamsville, Ontario, Canada
Re: Weatherlink has stopped responding
« Reply #1 on: January 07, 2017, 12:00:54 PM »
Maybe bypass VVP and go into the WL settings to see if you are indeed connected.
Offline WheatonRon
    • WUnderground
« Reply #2 on: January 07, 2017, 01:35:52 PM »
Have you gone into WL to see if the connection finds your station? If all else fails, try rebooting the computer.
Offline weathergirl
« Reply #3 on: January 07, 2017, 02:31:36 PM »
I've performed a reboot but the problem remains.  I cannot access the WL settings because the program just sits there with a spinning cursor. I think that it is trying to access the archive and can't for some reason. As I said before, I've never had a problem with WL until now. No changes have been made to my computer that I know of.
Ann-Marie
« Reply #4 on: January 07, 2017, 02:34:23 PM »
At this point I'd completely remove WL from your computer and reinstall it.
Offline weathergirl
« Reply #5 on: January 07, 2017, 02:40:28 PM »
You just read my mind. I'll do that and report back, thanks everyone.
Ann-Marie
Offline Scalphunter
« Reply #6 on: January 07, 2017, 03:12:11 PM »
or  create an new station just to see if the old one got corrupt.
Offline weathergirl
« Reply #7 on: January 07, 2017, 03:33:16 PM »
Well, it still isn't working, the WL window won't even open up now, it just stays stuck in the tray. StartWatch sees it as starting only. I also just noticed that the WL files stopped updating just after 11:00 pm last night. I will continue to search for a solution, thanks for your help, guys  :)
« Last Edit: January 07, 2017, 05:13:13 PM by weathergirl »
Ann-Marie
« Reply #8 on: January 07, 2017, 05:11:53 PM »
Did you completely remove it? Not just 6.0.3, but 6.0.0 or whatever prior version you had? Then did you use your CD ROM to re-install or just get it off the web or both?
Offline weathergirl
« Reply #9 on: January 07, 2017, 05:15:47 PM »
I did not delete anything, I just uninstalled Weatherlink 6.0.3 from Uninstall Programs, then downloaded the new file from the web.
Ann-Marie
« Reply #10 on: January 07, 2017, 05:19:14 PM »
So when you go to "remove programs" the only thing you see is 6.0.3, nothing else like 6.0.0 or 5.9.8 or whatever?
Offline dalecoy
    • Lee's Summit, MO
« Reply #11 on: January 07, 2017, 05:20:07 PM »
Am I correct that your weather site at http://www.beamsvillewx.ca/ is using the same computer and Davis hardware?  If so, that would rule out anything not associated with WeatherLink software.
« Reply #12 on: January 07, 2017, 05:20:51 PM »
I was just about to tell her to PM you. Nevermind.
Offline weathergirl
« Reply #13 on: January 07, 2017, 05:37:56 PM »
Yes, my site is using the same computer and Davis hardware. Yes, 6.0.3 is the only WeatherLink version in Uninstall Programs. I also received this error:
"WeatherLink installation not complete. Possibly upgraded to the wrong folder." I know it's in the correct folder.
Ann-Marie
« Reply #14 on: January 07, 2017, 05:42:51 PM »
6.0.3 may not be a full build, and you'll need 6.0.0. Do you have the CD or not?
Offline WheatonRon
    • WUnderground
« Reply #15 on: January 07, 2017, 05:48:48 PM »
Yes, I believe the download from Davis is only an upgrade. So you need to install the original version, then upgrade to 6.0.3 from the download.
« Reply #16 on: January 07, 2017, 05:52:12 PM »
Exactly. However a while back I had Davis e-mail me a FULL build that was 6.0.3. I'd go that route if you don't have the CD.
Offline WheatonRon
    • WUnderground
« Reply #17 on: January 07, 2017, 05:53:45 PM »
Undoubtedly, you had to prove to Davis you bought the original release, but yes, that would be the way to go.
« Reply #18 on: January 07, 2017, 05:54:34 PM »
I didn't have to prove anything.
Offline WheatonRon
    • WUnderground
« Reply #19 on: January 07, 2017, 05:56:18 PM »
Brett Lane probably put in a good word for you!
« Reply #20 on: January 07, 2017, 05:58:09 PM »
It's so old, I doubt they care.
Offline WheatonRon
    • WUnderground
« Reply #21 on: January 07, 2017, 05:59:30 PM »
It is so old, but the only Weatherlink they are selling!
Offline weathergirl
« Reply #22 on: January 07, 2017, 06:01:20 PM »
It figures, I know I have the cd but I can't find it, I'll keep looking. It's from years back, I hope that won't be a problem?
Ann-Marie
« Reply #23 on: January 07, 2017, 06:04:22 PM »
No. Like I said call Davis and have them e-mail you a full build. Whether it solves your problem......
« Reply #24 on: January 07, 2017, 06:06:03 PM »
Good point. #-o
