Author Topic: Meteotemplate - new free website template  (Read 630395 times)
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Meteotemplate - new free website template
« Reply #7225 on: June 18, 2017, 01:19:44 PM »
yes I see, stupid PHP float rounding. I will look at it next week.
J.
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update - Sea Temperature 1.1
« Reply #7226 on: June 18, 2017, 05:56:37 PM »
Hi guys,
- unit conversion fix
- data source URL fix
Enjoy
Offline i_fiorentino
  • Davis Vantage Vue, Boltek Stormtr., Mobotix M22-IT
    • Meteopistoia.it
Re: Meteotemplate - Block Update - Sea Temperature 1.1
« Reply #7227 on: June 18, 2017, 06:33:11 PM »
Hi guys,
Enjoy
No update, there is only 1.0 on your site
I'm confusing block / plugin  ](*,) ](*,) #-o #-o #-o
Ok, block installed.
But there is a possible bug.
Actually, viareggio's sea temperature  is 25 degrees
But plugin showed 2.5.....it's too cold for me  :roll:
Any ideas?
Regards,
Alessandro
« Last Edit: June 18, 2017, 06:46:27 PM by i_fiorentino »
Offline Jáchym
    • Meteotemplate
« Reply #7228 on: June 18, 2017, 07:37:05 PM »
Strange, I will look at it tomorrow
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« Reply #7229 on: June 19, 2017, 01:52:08 AM »
Hi Jachym, good to hear ya feeling better,
One has fallen foul of the windows 10 creators update (BIG one) i will have to wait hours no doubt before
the pc comes back online, so, my question is, to populate the DB with the missing data, which of WD's files
is it i need to use when updating the database please? is it the 62017lg.txt but then that does no include UV and
solar, that would have to be the vantage log or is there another log to suit the import system please?
Kind regards
Bashy
Offline Jáchym
    • Meteotemplate
« Reply #7230 on: June 19, 2017, 02:58:06 AM »
Yes that one, uv is not being used by the db,  with solar you would have to probably do it manually if wd can't do that,
Offline Bashy
    • Breckland Weather
« Reply #7231 on: June 19, 2017, 02:59:48 AM »
OK, thanks, will sort it once the machine stops dicking about.... Would UV be added in the future?
Kind regards
Bashy
Offline Jáchym
    • Meteotemplate
« Reply #7232 on: June 19, 2017, 07:13:18 AM »
Hi guys,
Enjoy
Any ideas?
Regards,
Alessandro
OK, this should fix it, make sure you delete the cache folder too
http://meteotemplate.com/blog/?p=2796
Offline Jáchym
    • Meteotemplate
Meteotemplate - New Plugin – Maps U.K.
« Reply #7233 on: June 19, 2017, 10:25:35 AM »
Hi guys,
this plugin shows dozens of climate-related maps for the region of the United Kingdom.
- national and regional maps
- 30-year averages (1961-1990, 1971-2000, 1981-2010)
- min/max/mean temperature
- degree days
- relative humidity
- days of hail, frost, rain
- wind speed
- pressure
- growing season length
etc.
DEMO: http://meteotemplate.com/blog/?p=2798
Enjoy
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Updates
« Reply #7234 on: June 20, 2017, 11:48:26 AM »
Hi guys
Block Update – Radar U.S. 7.0 - http://meteotemplate.com/blog/?p=2805
Block Update – UV 1.1 - http://meteotemplate.com/blog/?p=2802
Block Update - Interactive Graph 6.0 - http://meteotemplate.com/blog/?p=2800
Enjoy
Offline gillesroszak
  • Qui trop écoute la météo, passe sa vie au bistrot.
    • meteokerbach
« Reply #7235 on: June 20, 2017, 01:06:13 PM »
Hi Guys,
I just updated the block Interactive Graph
But the text is not clear at all due to the color of the font .
How can I change it ?
Offline Jáchym
    • Meteotemplate
« Reply #7236 on: June 20, 2017, 02:04:28 PM »
Hi Gilles, this is strange, this rather grey color should only be used for the grid line, no the text, I will check this.
I just checked your site and everything looks fine to me:
http://www.meteokerbach.fr/pws/template/indexDesktop.php
    • meteokerbach
« Reply #7237 on: June 20, 2017, 02:48:19 PM »
Hi Guys,
Yes all is fine now sorry
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update – Sea Temperature 2.0
« Reply #7238 on: June 20, 2017, 03:22:46 PM »
Hi guys,
based on your feedback I added support for multiple locations (max 5).
IMPORTANT! – if you are updating this block, you need to update your settings, the URL is now different, now you only include the last part of the URL, not the first part (see the settings) and you also need to delete the cache folder, it will NOT work with the original cache file.
Enjoy!
Offline Jáchym
    • Meteotemplate
Meteotemplate - New Block – Brazil – Current Conditions
« Reply #7239 on: June 21, 2017, 08:40:55 AM »
Hi guys,
this block shows an interactive map with hundreds of stations around Brazil, clicking the individual markers shows information about location, current conditions and for some also a photo.
DEMO: http://www.meteotemplate.com/template/indexBlockDemoWide.php?block=currentBR
Enjoy
    • Meteopistoia.it
« Reply #7240 on: June 21, 2017, 11:27:30 AM »
Hi Jachym,
probably co2 block is no longer available.
Please check it.
Look at my site here: http://www.meteopistoia.it/indexDesktop.php (left side after air quality block)
Regards,
Alessandro
Offline Jáchym
    • Meteotemplate
« Reply #7241 on: June 21, 2017, 11:36:45 AM »
thanks for letting me know, yes it is no longer available, just remove it from your homepage I will remove it from the demo too
Offline Jáchym
    • Meteotemplate
« Reply #7242 on: June 21, 2017, 11:40:08 AM »
Same with the CO2 plugin, it is not working anymore, I will post it in the Blog when I have time
Offline Jáchym
    • Meteotemplate
« Reply #7243 on: June 21, 2017, 05:57:08 PM »
Hi Jachym,
Please check it.
Regards,
Alessandro
Fixed, working again, see the Blog
Offline Jáchym
    • Meteotemplate
Meteotemplate - New Block – Marine U.K.
« Reply #7244 on: June 22, 2017, 08:39:32 AM »
Hi guys,
this block shows data from available ships/buoys around the U.K., and loads the available parameters (this varies and includes air and sea temprature, wave height, wave period, wind speed etc.) over the last 24h.
DEMO: http://www.meteotemplate.com/template/indexBlockDemoWide.php?block=marineUK
Enjoy
Offline Bashy
    • Breckland Weather
« Reply #7245 on: June 23, 2017, 01:11:19 AM »
Hi Jachym
Just looking at the stickers setup and i am seeing rain, baro and wind to .000
not even sure why the baro has a decimal see as it looks like its rounding it off, its currently 1012.9
but at time of screenshot, wind was 5.8mph and rain 0.0mm
Kind regards
Bashy
Offline Jáchym
    • Meteotemplate
« Reply #7246 on: June 23, 2017, 07:02:28 AM »
yes I see, this was more like an experiment, the only one that really works correctly is the interactive one and that one also is the only one which uses the API. The other ones are no longer supported, I guess I should update the plugin and just remove these, it is not working as I wanted and I would recommend using the interactive one, thats the only one working as it should.
Offline Bashy
    • Breckland Weather
« Reply #7247 on: June 23, 2017, 07:29:51 AM »
No worries, thanks, it's the one I chose anyway ☺
Kind regards
Bashy
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update – Twitter Feed 2.0
« Reply #7248 on: June 23, 2017, 08:09:09 AM »
Hi guys,
if you are logged in as the admin you will see a new button at the bottom of this block “Post current”, which when you press it will post the current conditions to your Twitter feed.
Enjoy
Offline Bashy
    • Breckland Weather
« Reply #7249 on: June 23, 2017, 08:17:39 AM »
I have a suggestion, how about a plugin to auto post to fb, I know fb made it harder but if Twitter can do it then it's possible, if you can figure it out, perhaps the end user will be able setup the post using the data from the api, perhaps create something like my macro does as seen here
https://www.facebook.com/breckweather/?ref=bookmarks
Just a thought is all, give you a challenge :)
Kind regards
Bashy
