Update,
As mentioned above, I connected the TX & RX on VP2 and USB to Serial adapter (IE: VP2 Tx to Adapter Rx and VP2 Rx to Adapter Tx) and when I started up Cumulus it states "Connected to station" but it's not pulling data. That's a start but, what I'm wondering is, the "connected" message due to Cumulus seeing the connection to the adapter or actually seeing connection to the VP2?
For me, WIN10 "Device Mangler" is seeing the Serial to USB adapter as being on COM5 which I have that setup in Cumulus and HyperTerm. In HyperTerm (19,200 / 8N0) it shows "connected" but I am not getting any type of VP2 response (IE: TEST, VER, STRMON).
If I connect the GND from the VP2 to the Serial Adapter then I get some type of power issue on the VP2 so...yea, like "crossing the streams!"
Update to the Update on the particular HiLetGo SERIAL to USB adapter that I'm chose, "This adapter is not genuine FTDI chip because it's based on so cheap a price, so it will be automatically bricked by the latest FTDI drivers in Windows." well, well...you get what you pay for!
The fix is to ensure that you use the older version of the FTDI drivers (2.8.3) on windows or use only with Linux or OS X. If you've already bricked it, please follow these instructions at below link (requires a Debian based Linux) **DEAD LINK**
http://www.minipwner.com/index.php/unbrickftdi000Drivers/Support:
http://www.ftdichip.com/FTDrivers.htmBesides giving me grief for my cheap purchase does anyone have suggestions, thoughts?
