Weather Station Hardware => Weather Station Pictures => Topic started by: Bushman on June 16, 2009, 05:07:22 PM
I was hesitant to use a tripod mount on my metal roof, so I fabbed up a mount for about $25 bucks. The nice thing about it is no chance of water leaks, the whole system pivots down to deck level for maintenance and it was cheap.
Materials:
Sat dish J-mount - $9
8 ft length 1 1/4" T6061 pole - $16
Thin metal for shim (I had some rolled plashing made of some sort of tin/lead that worked perfectly. I think a person could use thin aluminum as well) - free
Assembly:
Simple really. Remove the bracket off the J mount and install by predrilling holes and lagging to beam. They could go on a gable, or in my case a protruding ridge beam. Shim the tube and jam it into the J arm. Mount the weather gear on the arm. Drag it up the ladder and install the arm to the base mount. BTW, I did this with no assistant so it took a bit longer. If you had a person on the roof it could be a 10 minute job.
End Result:
(http://i816.photobucket.com/albums/zz85/eaglebayweather/EagleBayWeatherStation.jpg)
I mounted the anemometer higher than the bucket so that if I wanted to I could climb up to service the bucket and ISS. Now I can remove the bottom pin and pivot the whole thing for service. Seems to work right through my metal roof - 100% transmission. :)
Nice job!! Great idea especially for those of us getting up there in the years and hesitant in getting up there on the roof! :grin:
Where did you get the j-mount at?
also, did you jam the pipe that the station is on into the j-arm? I am trying to do the same thing you did. It is a great idea.
Bought the J-arm at a satellite store. Cost about 10 bucks. And yes, I shimmed and jammed it in. I should have added a set screw, but it is really tight.
I'm going to make this...looks great. I'm going to use some self-tapping hex head screws to hold pole into the j-pipe to keep it from moving. The only thing that worries me is it going to be stable as all that is holding it is the bracket. 8 Feet of pipe sticking up seems like a lot...will check it out.
Oh, yeah; almost forgot. You said you remove the pin to pivot it down... I used to install satellite and the j-arm uses a self-tapping screw on each side of the arm to hold it from pivoting down. Did you drill it out and install a pin? Sounds like a great idea. I'm going to Home Depot tomorrow and get some 1 1/2" rigid to make this.Thanks for the idea...Barry.
Pin was the wrong word. This particular J arm uses a bolt with lock nut to keep it up. There is a pin that I installed as backup. Pull that and loosen the locknut and it then pivots down. Be aware that the rain bucket screen might come out when you pivot it down.
I am really happy with this mount system; has handled 40-50 mph winds no problem.
Would the rain gauge record some rainfall when you're doing this?
Not if you put the VP console into setup mode before you start.
Love those J mounts, very versatile :grin:
Good to know!
Would really be funny if the rain guage was clogged up and had a 4" rain the night before you lowered it to work on it...LMAO!
I think that would be "when", not "if"! The only time you know it's clogged is after you've had a 4" rain and it reads zero. I'd think SOP for that mounting would be to stand well to the side when you lower it.
Materials:
Assembly:
End Result:
Does it sway in the wind?
Not enough to create false rain bucket tips. Winds to 80-90 kph.
