Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
window.onload = function() { var updateTimer; var cp = ['N', 'NNE', 'NE', 'ENE', 'E', 'ESE', 'SE', 'SSE', 'S', 'SSW', 'SW', 'WSW', 'W', 'WNW', 'NW', 'NNW']; $('[id$=Table]').DataTable({ 'paging': false, 'searching': false, 'info': false, 'ordering': false }); function updateTimeout() { // Change the icon on the last update to show that there has been no update for a while $('#LastUpdateIcon').attr('src', 'img/down.png'); } var data = returndata(); var data = JSON.parse(data); // restart the timer that checks for the last update window.clearTimeout(updateTimer); updateTimer = setTimeout(updateTimeout, 60000); // Get the keys from the object and set // the element with the same id to the value Object.keys(data).forEach(function(key) { var id = '#' + key; if ($(id).length) { $(id).text(data[key]); } }); $('#BearingCP').html(cp[Math.floor(((parseInt(data.Bearing) + 11) / 22.5) % 16)]); $('#AvgbearingCP').html(cp[Math.floor(((parseInt(data.Avgbearing) + 11) / 22.5) % 16)]); $('.WindUnit').text(data.WindUnit); $('.PressUnit').text(data.PressUnit); $('.TempUnit').text(data.TempUnit); $('.RainUnit').text(data.RainUnit); var lastupdatetime = new Date(); var hours = lastupdatetime.getHours(); var minutes = lastupdatetime.getMinutes(); var seconds = lastupdatetime.getSeconds(); if (hours < 10) { hours = '0' + hours; } if (minutes < 10) { minutes = '0' + minutes; } if (seconds < 10) { seconds = '0' + seconds; } var time = hours + ':' + minutes + ':' + seconds; $('#lastupdatetime').text(time); function returndata() {$.ajax({ url: './realtime2.php', dataType: 'json', success: function(data) { console.log(data) } });};return data;}
