Hello,
Downloaded the steel gauges. I am using WD so I made the change to the gauges.js. I checked the box in WD for the
To process the customclientrawlocal.txt, in WD you need to:
in control panel, webfiles/web page setup, real time ftp setup
see the custom client raw file setup...and tick to create that
make sure the needed customclientrawlocal.txt is in the clientraw folder location
But I do not seeing customclientrawlocal.txt uploading to my website. What am I missing / doing wrong?
I figured out by restarting WD the customeclientraw.txt is uploading. What about customclientrawlocal.txt is that suppose to be uploading. I put a copy in the WD webfiles folder in WD. Not seeing that upload. Is customclientraw.txt the correct file to upload?
Also what is the next step? I see something about changing location but not sure where and how I do that.
The provided HTML files gauges-ssT.htm etc, are designed to be 'processed' by Cumulus before uploading to the web site and renaming as gauges-ss.htm This processing replaces all the tags like <#location> with general information about your station (the station name) in this case.
To use the templates with WD you will have to manually edit the HTML file, and replace each of these tags with information appropriate to you. I suggest you then save the file as gauges-ss.htm
You will also want to replace the Menu bar at the bottom of the HTML page which is specific to the Cumulus sample web pages.
Then what files do I load to my website etc?
Any help would be appreciated.
Bob
