Author Topic: Inadvertent "Cool" emoticon  (Read 2010 times)
« on: September 21, 2014, 01:17:11 PM »
Is there a way to suppress emoticons/smileys for a particular situation?
Every time I type
(USB6.8) I get (USB6.8) with a "cool" smiley. Even though the "cool" emoticon is one of my favorites, in this particular case it is more of a problem. I have used [USB6.8] instead, if I catch it in the preview.
Not a big problem, and if there is no "off" control for smileys, I'll just keep using the brackets instead.
Offline W3DRM
    • Emmett Weather
Re: Inadvertent "Cool" emoticon
« Reply #1 on: September 21, 2014, 02:06:25 PM »
When you reply to or create a new post, you can turn-off smilely's for that post. You will find it under the "Attachments and other options" section just below the area you type-in your post contents. Click on the + to see the options available to you.
--- RIPE Atlas Probe - 32849
« Reply #2 on: September 21, 2014, 02:47:52 PM »
Ah! Thanks. I didn't expand that selection, but now I see it.
Don't use smileys.
Offline WeatherHost
« Reply #3 on: September 21, 2014, 03:06:37 PM »
Use more spaces.
( USB6.8 )
« Reply #4 on: September 21, 2014, 04:57:12 PM »
Or... turn off the auto-formatting selectively by surrounding it with
[nobbc](USB6.8)[/nobbc]
Then it will appear as (USB6.8) on display instead of (USB6.8)
« Reply #5 on: September 21, 2014, 10:18:43 PM »
I sort of like this one. Is there a "magic button" for it?
« Reply #6 on: September 21, 2014, 11:12:02 PM »
Yes,
Not on quick-reply, but the editor now has a button that will insert
[nobbc][/nobbc] for you.
Best regards,
Ken
Offline W3DRM
    • Emmett Weather
« Reply #7 on: September 21, 2014, 11:31:27 PM »
Yes,
Best regards,
Ken
Hey Ken, that is GREAT! i didn't know that. So, today, I learned something new...  \:D/
« Reply #8 on: September 22, 2014, 08:35:38 AM »
Now that is  8-) Thanks!
(USB6.8) (just tried it....)
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #9 on: September 22, 2014, 12:01:32 PM »
Almost as bad as autocorrect. I texted a co-worker about a meeting later after work. I sent..
" ....enuf time to get a nap in..."
it came out....
".....buff time to get a nap...."
