I recently purchased an aculink internet bridge, a color weather station and an additional tower sensor. My plans for this are to remotely monitor indoor and outdoor temps at a second home. I'm getting it all set up and that was simple. The weather station displays the indoor temp as expected and the outdoor sensor as expected. The signal strength shown on the weather station for the outdoor sensor is 4 bars, very strong. It is only about 30 feet away through one wall.
I have the aculink bridge setup and registered and have an account created on the aculink site.
The problem is that the bridge doesn't pick up the sensors unless they are very close, less then 10 feet away. The outdoor sensor is only 30 feet away and doesn't get picked up at all. The indoor sensor is about 6 feet away in the same room and it only shows a strength of 1 bar on the aculink site.
I have moved the bridge to several different locations. There are no major appliances or electronics nearby. The distance is well under the 330ft stated range. There are no masonry or stone walls.
Has anyone else had problems with the bridge not picking up sensors that a weather station can easily pick up? I would have expected the receiver on the bridge to be better than the receiver on the weather station. From my experience it doesn't work.
I have emailed acurite and have not yet had any response. If I don't get this working well soon I'm going to return the entire setup and look for something different.
Any help or ideas is greatly appreciated.
