I am NOT happy at all.
At first it lit up, but I couldn't tell if it was normal, abnormal, or just because they hadn't activated it yet. The Threshold light stayed on for a long while, several minutes, then finally turned off. The Comm light was off also when it should have been on according to the papers. There was a mention that this could be a port problem, so I looked into setting open ports using the IP addresses in the papers. One of the steps in the modem/router information was to reboot both the modem and the device.
Modem came back up OK, but when I plugged the sensor back in, only the power light was on and it started making a weird whining noise. Tried it again, same thing. Now, it doesn't do anything. No lights, no noise, no nothing.
What is bugging me is that the LAN switch/AP/Repeater I have out there that has been working fine for weeks, now won't connect to the LAN and is doing other strange things. I don't know if the sensor died and took the switch with it, or what's going on. I called TOA, got a recording.
Somewhere during the whole process outside installing the PVC and adapting it to what I needed for this install, I dropped a can of that purple PVC cement primer. It was open and it splashed. Everywhere. Including the light tan vinyl siding on the garage. I have no idea if it will ever come off.
I am NOT happy.
