New to this site and to weather. Hubby is thinking of upgrading current system. Wants a display unit that will display 8 sensors. Also wants to be able to check remotely. Any help, suggestions would be greatly appreciated.
It would be beneficial to know what the current system is to make sure compatibility with old data and databases is preserved. Just because you need a new system doesn't mean you should throw the entire old system out. In some cases sure, but often there are workable parts that work across brands. In some cases perhaps you may want to maintain the existing manufacturer's services (Weatherlink.com, myAcurite.com, Ambientweather.net).
What is the current old system brand/model?
What additional hardware if any is used (Meteobridge, Data logger adapters, sensors) ?
What additional software if any is used (Weather-Display, WeatherCat, WeeWx, Cumulus, VWS...etc.)?
What type of computer is used for said software (Windows, MacOS, Linux)?
Also where is the current station publishing data to? Just Weather Underground?... or others likes CWOP, PWSweather, WeatherCloud, etc. And are there any new requirements?
Lastly... What is your budget?
