Author Topic: placefile.txt poacher for Blitzortung at 208.113.219.243  (Read 1669 times)
« on: August 03, 2016, 01:03:07 PM »
I see this in my logs that 208.113.219.243 is pulling my Blitzortung USA placefile.txt every 2 minutes (likely via a cron job).
The 208.113.219.243 IP doesn't have a website per se, but a DNS reverse shows it as
arthur-middleton.dreamhost.com
It is not a normal GRLevel3 fetch since they have URL arguments included and usually only pull new data every 5 minutes.  The every 2 minutes is annoying, and I'm going to block the accesses unless the owner of that website gives me a PM contact to explain why they need it at 2 minute intervals -- the file is only generated every 5 minutes.
Ken
Offline Maumelle Weather
    • Maumelle Weather
Re: placefile.txt poacher for Blitzortung at 208.113.219.243
« Reply #1 on: August 03, 2016, 01:26:31 PM »
I'd cut them off, Ken. I gave up a long time ago about asking nicely for others to quit doing crap like that. I would just block the whole CIDR, if it was me.
GR2AE, GR3, Cumulus
« Reply #2 on: August 03, 2016, 01:31:34 PM »
Thanks John... I did put their server deny in .htaccess this morning.  I'll see if that prompts them to contact me or not.
I don't mind regular usage of the Blitzortung USA/GRLevelX placefile for folks using GRLevel3 or GRLevel2/Analyst -- they are quite welcome to use the feed and their individual requests every 5 minutes are not a big deal (about 100Kb/access of a .txt file).  I do mind an automated pull from a script at intervals less than 5 minutes, especially when the IP leads to a non-responding website (so no further research is available to me)   :evil:
    • Maumelle Weather
« Reply #3 on: August 03, 2016, 01:35:50 PM »
I'm going to venture it was a person that got a hold of the URL when someone else posted it earlier in the year. Don't remember who it was right off hand who did that.
GR2AE, GR3, Cumulus
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #4 on: August 03, 2016, 01:41:09 PM »
I wouldnt even think about this and block them straight away :D
