Author Topic: No longer connecting **solved**  (Read 951 times)
Offline asherah
« on: December 19, 2017, 06:27:26 PM »
Hey guys, I'm a new Meteobridge user, just flashed my MR3020 today. After a shaky set-up, I finally got my MR3020 to send data. It was working well with rapid fire updates to WU for almost an hour when it unexpectedly stopped. I got an error message, (error connect socket 192.168.0.13: port 22222: No route to host). I'm not sure where I went wrong in setting up my devices. I have a Davis Vantage Vue with the IP data logger. These are the messages I'm receiving. Thanks in advance for the help!
logger (19.12.2017 18:15:05): historical data loaded (19 records).
logger (19.12.2017 18:15:05): data logger (version 5.0w, build 11742) started.
logger (19.12.2017 18:15:08): error connect socket 192.168.0.13: port 22222: No route to host
logger (19.12.2017 18:15:12): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (19.12.2017 18:15:12): services paused.
logger (19.12.2017 18:15:38): error connect socket 192.168.0.13: port 22222: No route to host
logger (19.12.2017 18:16:38): message above repeats 2 times.
logger (19.12.2017 18:17:05): give up waiting for sensors after 120 secs.
logger (19.12.2017 18:17:05): services activated.
logger (19.12.2017 18:17:08): error connect socket 192.168.0.13: port 22222: No route to host
logger (19.12.2017 18:19:38): message above repeats 5 times.
« Last Edit: December 25, 2017, 06:26:32 PM by docbee »
Offline waiukuweather
Re: No longer connecting
« Reply #1 on: December 19, 2017, 07:02:39 PM »
do you happen to have the ip data logger also updating weatherlink.com?
Offline asherah
« Reply #2 on: December 19, 2017, 07:35:00 PM »
No, I figured I'd take it 1 step at a time. I wanted the WU upload to work before trying anything else.
Offline asherah
« Reply #3 on: December 19, 2017, 07:37:21 PM »
So I plugged my ethernet cable from my weatherlink ip data logger directly into my modem and it's uploading on the Meteobridge software.
« Last Edit: December 19, 2017, 07:50:27 PM by asherah »
Offline docbee
  • Moderator
    • smartbedded
« Reply #4 on: December 25, 2017, 06:26:20 PM »
Looks like a dynamic IP issue in your LAN. Please give the WLIP logger a fixed IP in your LAN.
