Hi all,
Long story short, the other day i took down my station to do some much needed cleaning and maintenance of the entire apparatus. However, I noticed that the weather console was still pulling/reporting a pressure reading.
The ISS was in test mode (4th dip switch up, all others down) from start to finish of the device, so data wasn't...or should be getting transmitted. Even more so when the solar and battery were pulled out.
Which narrows it down to this... the Vantage console is taking pressure readings?
While this may seem like a redundant question, if the pressure sensor is on the Vantage2 Console... why isn't it on the actual ISS box outdoors? Would the indoors of a house generally offset the accuracy of pressure readings?
