Author Topic: WH2310 solar illumination too high  (Read 770 times)
Offline DoctorKnow
« on: August 02, 2017, 10:56:32 AM »
On meteobridge the live data is showing solar illumination as too high. Right now the console says 433 W/m2 but what is being shown on the meteobridge live page is 1400 W/qm. Can this be corrected? Thanks Doc. It may be a while before I can get back to any response.
Offline docbee
  • Moderator
    • smartbedded
Re: WH2310 solar illumination too high
« Reply #1 on: August 02, 2017, 06:58:11 PM »
When you reboot and grab latest update it should be fine, Please report if situation does not change for you.
Offline DoctorKnow
« Reply #2 on: August 02, 2017, 07:57:25 PM »
I rebooted.
My console says 7.78 w/m2
Meteobridge reading...
Indoor3 sec23.0°C 42% 1017.4hPa (1017.4hPa)73.4°F 42% 30.04inHg (30.04inHg)
Outdoor3 sec26.3°C 62% (dew 18.4°C, heat 26.3°C)79.4°F 62% (dew 65.1°F, heat 79.4°F)
Wind3 sec1.0m/s (avg 0.0m/s) 135° SE2.2mph (avg 0.0mph) 135° SE
Rain3 secrate 0.0mm/hrate 0.00in/h
 UV3 sec 0.0uvindex 0.0uvindex
Solar3 sec 0W/qm0W/qm
Should the reading above that shows 0 now not be the same as the console?
« Last Edit: August 02, 2017, 07:59:51 PM by DoctorKnow »
