Author Topic: WD and popup window  (Read 1130 times)
Offline jpk1018
  • http://www.madrussianweather.com/#
    • Mad Russian
WD and popup window
« on: December 13, 2016, 09:26:36 PM »
Is there anyway short of turning off Anything weather uploads to stop the popup upload window from showing up on my computer screen every 10min?
I think weather bug uploads do it to. Their just kind of annoying.
Offline waiukuweather
Re: WD and popup window
« Reply #1 on: December 13, 2016, 09:46:35 PM »
if you mean the FTP program
then you can set to have that run hidden in the system tray
in the connections setup, in the FTP/internet setup
Offline jpk1018
    • Mad Russian
« Reply #2 on: December 13, 2016, 09:57:02 PM »
No I don't believe it's the ftp program, I am just sending my stations data to weather anything it's one of the publications on the control panel that you can sign up with. Every 10 min I get a popup window showing the connection and the data files I send to them. It does it with weather bug also. Like I said it's just annoying and I haven't found anywhere to minimize it.
Offline jpk1018
    • Mad Russian
« Reply #3 on: December 13, 2016, 10:01:22 PM »
I did click the minimize box and will see if that helps. Thanks
Offline jpk1018
    • Mad Russian
« Reply #4 on: December 13, 2016, 10:16:51 PM »
And that seems to of fixed it Thank You :grin:
« Reply #5 on: December 13, 2016, 10:33:36 PM »
I would tick to show in system tray and not task bar (minimised)
