Author Topic: MOBILE Dashboard Ver 1.91 RELEASED  (Read 61128 times)
Offline BurnsvilleWeather
  • Burnsville, MN USA
  • Retired from Weather!
« on: February 13, 2011, 03:21:37 PM »
UPDATE:  Version 1.91 is now released to go with Alternative Dashboard Version 6.9x.
UPDATE:  Webster Weather Live is now called Burnsville Weather Live.  All current, past and new script updates will be hosted at the new site.  See message 1 for link!   Thanks!
A NEW Multi-Language capable MOBILE version of the Alternative ajax-dashboard Version 6.81 from Webster Weather Live is now released. This version is built totally on the 6.81 version and requires that you are already running this version on your site to work. This version also requires the NEW Version 3.01 of ajaxWDwx.js that is based off the 9.13 version by Rainer to work!!! (Already part of alt-dashboard V6.81) This MOBILE version of the dashboard uses the Temperature, Current Conditions, Wind, Rain and Several other sections for a Mobile view:
  • Full Radar page by tapping radar on main screen
  • Fully updated to match Alternative Dashboard Ver 6.81 or later
  • Multi-Language file support
  • Includes Atoms Alerts at top
  • External Configuration file to make updates easier
  • Based on the full dashboard version 6.xx so no complicated setup, it's plug and play!
  • Larger Temperature section with station records or optional Weather Underground records
  • Optional UV Display
  • Uses Weather Underground Radar Display
  • Displays well on Androids EVO, iPhone 4, iPhone 3, Droid X so far!
  • Support for animated icon set
Version 1.02 - 26-Feb-2011
Fixed a problem that could cause a preg_match function error.  Just replace WWL-mobile.php from the archive
Version 1.10 - 01-May-2011
By Request, added short term forecast Icons to bottom of display.  Just replace WWL-mobile.php if upgrading from 1.0x versions
Version 1.20 - 11-Jul-2011
Changed UV to be Icons at both day and night (also if no UV).  Added Solar Icon if you have both UV and Solar.  Added options to select no extended forecast, only one line of extended forecast or all.  Added footnote.  Fixed issue with UV icons not showing for some users (Thanks Jerry)
Version 1.30b - 17-Jul-2011
Added a link to the radar image to a special version of the local radar specially setup for mobile smartphones.
Version 1.32 - 31-Jul-2011
Modifications for UV so values over 11 show correctly now.  Updates to Solar. Fix for error in Android code- thanks Alessandro!
Version 1.50 - 19-Nov-2011
Added support for animated icon set.  Added more language translation abilities.  Just replace WWL-mobile.php from the archive
Version 1.70 - 17-May-2012
Display layout changed.  Added more support for Rain totals.  Minor fixes and updates to match Alternative Dashboard Ver 6.7
Version 1.71 - 15-Sep-2012
Added ability to display the Feels Like and/or Wind Chill/Heat Index under the main tempature like in the alternative Dashboard version 6.71.
Version 1.81 - 17-MAR-2013
 REQUIRES new version 3.01 of ajaxWDwx.js provide with version 6.81 main script.
Requires change to Settings-weather.php from Alternative Dashboard 6.81 to work.
Please read the READ-ME-1ST file in the archive and have already upgraded to Alternative Dashboard V6.81
BEFORE trying to add this version.  Thanks!
Version 1.91 - 11-FEB-2014
  • Now with button to display full site
  • Added more readings to display
  • Added footnotes to radar page
  • Many minor changes from users in forum
PLEASE EDIT FOOTNOTE ABOUT NOT AFFILIATED WITH NWS, I MADE ADDITIONS THERE THAT WILL NOT FIT YOUR SITE!
This one is really so easy to setup, extract the 4 files to your main directory edit php file to add your site name near the top of both .php files, set a couple other settings right below that in both for extended forecast and footnote and create a link to use it and you're done!  How simple is that!!  Please let me know if you see any issues with the display on any smartphone.  It should work well on most all of them!
Then just create a QR code (Bar code for smartphones) so your site's users can get to it from their phone without having to type it in:
Instructions to creat that are in the archive.
You can get the download at:
www.burnsvilleweatherlive.com/wxScripts.php
« Last Edit: February 11, 2014, 08:55:39 PM by BurnsvilleWeather »
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
Re: New MOBILE Dashboard Beta Ver 0.10 RELEASED
« Reply #1 on: February 13, 2011, 04:54:46 PM »
Thanks Scott, that's another great addition..
http://cvweather.org/m-cvweather.php
But I'm really new to smart phones, got mine on Friday. I went to you website http://www.websterweatherlive.com on my phone saw the image. How do I scan it? My choices were to save, view, set as wallpaper or share. Tried view didn't work. What am I doing wrong? :sad:
« Last Edit: February 13, 2011, 08:40:29 PM by ed2kayak »
Ed
« Reply #2 on: February 13, 2011, 05:28:30 PM »
http://cvweather.org/WWL-mobile.php
You need a QR code reader.  It is part of most of the bar code apps for the phones. (You scan the bar code with the phone, you don't do anything with the image itself.)   Once you scan it it should give you the option to open it in a web browser.
Scott
« Last Edit: February 13, 2011, 05:36:48 PM by WebsterWeather »
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
« Reply #3 on: February 13, 2011, 09:07:44 PM »
Very nice Scott
Software: WeatherDisplay
Offline ed2kayak
  • Ed
« Reply #4 on: February 13, 2011, 09:08:36 PM »
I was confused! Looking at your site with FF the QR code doesn't show up. I'm thinking scan what? It does show up ok in IE.  As far as feature request,
it would be nice if you could put indoor temp somewhere, I know its a tight squeeze.
Ed
« Reply #5 on: February 13, 2011, 09:17:58 PM »
I'm confused why it wouldn't show in FF, its just a JPG image!  (UPDATE: Just downloaded FF and sure enough it don't show!)(Update again:  Found the problem with the image not showing on the menu.. a \ instead of a / in the img tag... FF is so fussy!)
Scott
« Last Edit: February 13, 2011, 10:19:53 PM by WebsterWeather »
  • Mark
« Reply #6 on: February 13, 2011, 09:48:39 PM »
I use Opera for my browser on my cell and this page looks good.. http://cvweather.org/m-cvweather.php
« Last Edit: October 15, 2011, 05:00:21 PM by ALITTLEweird1 »
« Reply #7 on: February 13, 2011, 10:01:29 PM »
But mine Is showing as full screen which means I have to zoom in, any ideas?
http://www.snoqualmieweather.com/WWL-mobile.php
I think the major part of the problem is, you're using version 5 of alternative dashboard and you need to have version 6.xx running.  Many of the config and code is all from version 6.
Scott
  • Mark
« Reply #8 on: February 13, 2011, 10:11:35 PM »
Scott
I knew it needed version 6 and I changed a few things to get it to work. The size is the only issue Im having on my cell..
« Reply #9 on: February 13, 2011, 10:15:58 PM »
Scott
You will at least need to change the size of the Current Condition ICON to the smaller size, it's pushing the column too wide.  That could be part of it.
Offline ke9lz
  • De Pere - Athelstane Weather
    • De Pere Weather
Re: New MOBILE Dashboard Beta Ver 0.11 RELEASED
« Reply #10 on: February 13, 2011, 11:24:25 PM »
Thanks Scott!  I can report that it works on my Blackberry Curve.  Have it running at http://depereweather.com/WWL-mobile.php .  That was to easy to get running :grin:
Steve
Steve (KE9LZ)
Athelstane Weather
Blitzortung 1177, 1565
« Reply #11 on: February 13, 2011, 11:28:48 PM »
Steve
Very good to hear!  Thanks!!
Scott
Offline Stetson1
  • Cordera Weather
    • Cordera Weather
« Reply #12 on: February 14, 2011, 12:23:52 PM »
Looks great on my Droid X. I'll try and get this running one night this week from my site. Thanks for the great work.
Todd
« Reply #13 on: February 14, 2011, 01:42:33 PM »
Todd
Thanks Todd, best part about this script is, it's really plug and play, drop 3 files in and it's all set to go! (*IF* you already have Version 6.xx running of the alternative dashboard!)
Scott
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
« Reply #14 on: February 14, 2011, 03:11:34 PM »
Hi Scott,
Thanks for another great script, but looks like I have this issue for some reason:
Fatal error: Call to undefined function langtransstr() in /home/dwayneya/public_html/wx/WWL-mobile.php on line 330
Take a look at http://www.dwayneyamato.com/wx/WWL-mobile.php and see what you think.
My main page is at http://www.dwayneyamato.com/wx/index.php
Main page is working well but it seems something is amiss with something.
Thanks for any suggestions.
--Stan Y.
   Maui, Hawaii
 --- Blitzortung ID: 993
 --- FlightRadar24 ID: F-PHOG1
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
Webcam: Axis 211
Offline Silversword
  • --Stan Y.
« Reply #15 on: February 14, 2011, 03:49:21 PM »
Hi Scott,
Never mind my last post.  Figured it out.  I forgot about the last few lines that we worked on the dashboard with this error.  Man, memory is short nowadays...
Got it working okay now.
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
« Reply #16 on: February 14, 2011, 04:01:38 PM »
Hi Scott,
--Stan Y.
   Maui, Hawaii
I know what you mean, I have an excellent memory... for about 15 seconds!
Scott
Offline Silversword
  • --Stan Y.
« Reply #17 on: February 14, 2011, 04:25:33 PM »
Hi Scott,
Yep,  mine is shorter as the days go by.
Another issue,  how do I change the radar image to Hawaii? Or closer to Maui rather than the whole state.
Thanks again for a great script and I got it tested on my Brother-In-Law's Droid X with the "bar code" reader.
See the attached image.
Catch you later,
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
« Reply #18 on: February 14, 2011, 04:43:06 PM »
Stan,
Looks great on my Android EVO!  Love the background effects!   The radar should follow exactly what you chose in the main script for the WU Radar.  That was part of the original Ajax Script from Ken.  Do you use it on your main site?
Scott
Offline Silversword
  • --Stan Y.
« Reply #19 on: February 14, 2011, 05:06:39 PM »
Hi Scott,
This is what I am using on my index page:
  <img src="http://radblast-mi.wunderground.com/cgi-bin/radar/WUNIDS_map?station=HMO&amp;brand=wui&amp;num=6&amp;delay=50&amp;type=N0R&amp;frame=0&amp;scale=1.000&amp;noclutter=0&amp;t=1220645586&amp;lat=0&amp;lon=0&amp;label=you&amp;showstorms=0&amp;map.x=400&amp;map.y=240&amp;centerx=320&amp;centery=240&amp;transx=-60&amp;transy=-80&amp;showlabels=0&amp;severe=0&amp;rainsnow=1&amp;lightning=1&amp;smooth=1
If this is of any help...
Where do I find $SITE['WUregion'] in the following line, then I think, I will be able to show the Radar in my area?  What do you think???
<img src="http://icons.wunderground.com/data/640x480/<?php echo $SITE['WUregion']; ?>_rd_anim.gif" alt="Regional Radar"
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
« Reply #20 on: February 14, 2011, 05:12:15 PM »
Hi Scott,
Stan,
I think that is all setup in setting.php.  I'm at the office right now so I can't look, but I'm pretty sure thats it.
Scott
Offline Silversword
  • --Stan Y.
« Reply #21 on: February 14, 2011, 05:20:09 PM »
Hi Scott,
Thanks for the reply and will take a look at that portion and will work with it later as I have to go get our grand children from their schools. Sitting chores are coming up..
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline Silversword
  • --Stan Y.
« Reply #22 on: February 14, 2011, 05:37:19 PM »
Hi Scott,
Looks like you are right but it does not work outside of the regions that is listed in the following lines in the setup.php script:
$SITE['WUregion']   = 'sw';            // Wunderground regional maps
// 'sw'=SouthWest, 'nw'=NorthWest, 'mw'=Midwest
// 'sp'=South Central, 'ne'=North East, 'se'=South East
I tried to put in 'hi' in place of the 'sw' but no workie.  Know of any other regional maps ID that I could use.  I will have to figure this out later.
Thanks again for your input and support.
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
« Reply #23 on: February 14, 2011, 05:39:29 PM »
Hi Scott,
You should be able to just replace the script line that calls the WU Radar with the exact line you are using on your site now, just set the width and height smaller as I did.  It should work
Scott
Offline Silversword
  • --Stan Y.
« Reply #24 on: February 14, 2011, 05:57:38 PM »
Hi Scott,
Again thanks for the reply and suggestion.  Will try that later tonight and see what happens.
--Stan Y.
   Maui, Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
