Author Topic: Ws-2000 update ver 1 3 8 stuck  (Read 656 times)
Offline Platokidd
  • top side land of Lincoln
« on: March 21, 2019, 10:49:20 AM »
Not sure what to do here but its hung-up , stuck. Been this way for 30 minutes.
Ambient
1-WS-5000 1-WS-2902A 2-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-PM2.5 (WH41B) 3-WH31 1-SRX100LX
ECOWITT
2-HP2550 2-HP2560 2-GW2000 2-GW1100
2-WS68 1-WS80 1-WH32EP 10-WH31 1-WH40
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
1- Storm Sensor-Zelda the dog ;)
Re: Ws-2000 update ver 1 3 8 stuck
« Reply #1 on: March 21, 2019, 01:08:18 PM »
I've flashed my WS-2000 many times forwards and backwards and tested every version multiple times in my testing. I've never seen that happen. Seems like it got stuck. Good rules to follow when flashing firmware is to always do it when weather is good and less likely for power interruption. Also wait it out because an interrupted firmware can leave you with a bricked device. Being that you've waited 30 minutes and it hasn't changed means that it probably won't change so there is no point waiting it out further. I think the good news is that it says 0% complete. So hopefully if you power it down and back up it will start up again and you can try the "Upgrate" :) again. One last thing you could try before powering it down is to remove the SD card and plug it in again and see if it recognizes it. It may have trouble reading your SD card. Worth a shot a this point. If it is bricked and wont power up then you'll need to arrange for RMA. If you do get a second chance to "Upgrate" (sorry can't resist), then make sure to format the SD card as FAT32 and copy the .bin firmware file back on. Be sure you trust that SD card if not find another one. It is best to use small SD card like 4GB or 8GB as recommended by manufacture.
« Last Edit: March 21, 2019, 02:15:45 PM by galfert »
Offline Sir_MAK
« Reply #2 on: March 21, 2019, 01:37:33 PM »
Mind did that on the last update too.  Waited about 15 minutes after it showed the 100% erased.  I powered down, re-seated the SD, and powered it back up.  Fortunately it started back up and reran the erase and then loaded the new firmware with no issue.  I figured I didn't put the SD card in fully the first time.
Ambient WS-2000, Central Ohio - WU WC
Ambient
WS-2902, Lake Erie   -    WU WC
Offline Platokidd
« Reply #3 on: March 21, 2019, 04:41:21 PM »
Got tired of waiting for Ambient tech-support to respond. Thus risking a brick in the making,  I removed the sd card reinstalled it and it worked.
The upgrade seems to look a tad nicer and easier to read.
« Last Edit: March 21, 2019, 04:43:09 PM by platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
« Reply #4 on: March 22, 2019, 10:48:14 AM »
Did you have to power cycle? Or did you just remove and reinsert the SD card and it continued?
Offline Platokidd
« Reply #5 on: March 22, 2019, 03:30:44 PM »
Removed / reinstalled the SD card and the upgrade started over. Think I got lucky. :lol:
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
« Reply #6 on: March 22, 2019, 04:24:53 PM »
Very interesting. Good to know. Thanks. I'm sure this will help other people to try this first and not go for the power cycle unless it is a last resort.
Offline Platokidd
« Reply #7 on: March 24, 2019, 08:07:00 AM »
This setting appears to not be working. Asuming this should lighten and darken the screen at times show.
Shouldn't this make adjustments to the screen brightness / darkness at some point?
« Last Edit: March 24, 2019, 08:10:55 AM by platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Mandrake
« Reply #8 on: March 24, 2019, 01:53:41 PM »
I will admit I have not noticed the auto screen dimming function work on my display though the Automatic Control definitely does.
I notice you don't have it ticked.
Once ticked it effectively controls when it switches the screen on and off. For instance I have mine switch off during the night hours and switch on again at 0630 when I tend to get up.
Is that what you meant?
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
« Reply #9 on: March 24, 2019, 06:51:26 PM »
The automatic brightness adjustment is a sort of override for the manual controls on the home screen. It is not something that is scheduled. It is something that is enabled or disabled at all times. Its supposed to limit at max brightness and a minimum brightness that can be dialed in on the home screen. Although in practice is is either a bit counter intuitive or doesn't work all that well. I'd say it needs some firmware tweaking revising. I've gotten it to do some things like force a dim display or force a middle brightness or a force a full brightness  but how I got it to do that an how the settings made any sense was not intuitive and it was more like trial and error even when you accomplish it, you still are left scratching your head trying to make sense of it. After messing it with for a while I just decided to ignore this feature. Even if it worked as I think it was intended to, I still think I would not use it.
The automatic turn on/off of the backlight does work well based on the times you set. That feature I do use to maybe save the screen. If you enable this feature and the screen is ever off you can hit any button and it will turn on the screen, but it won't invoke whatever that button normally does...it just turns on the screen. The screen will then stay on for exactly 1 minute and then turn back off....until the scheduled time is reached. If you turn off the backlight during the turn on period it will remain off until the next turn on scheduled time. If you turn it the backlight off and you have not enabled the automatic backlight feature then the display will permanently stay off until you turn it back on or there is a power outage (or you manually power cylcle).
