Author Topic: Meteobridge trouble with Anemometer transmitter kit  (Read 687 times)
Offline alexeysailman
    • MORSKAYA10 WEATHER STATION
« on: February 16, 2019, 03:05:12 AM »
Hello.
I have Envoy8x + (ISS) Vantage Pro 2 + Anemometer transmitter kit + Meteobridge (TL-MR3020 V3). Envoy8x connected to my Meteobridge via Davis USB data logger.
First of all, I reset the Meteobridge settings to factory default and configured the network and Davis Envoy8x (setup anemometer transmitter kit with Weather Data Transfer Utility), ISS -  auto-detected. Data from the ISS block and from the Anemometer transmitter kit are unloaded correctly. In the tab "Live Data" in Meteobridge (picture in attachment), the parameter Wind #1 shows the current situation in the wind (highlighted in red) - from Anemometer transmitter kit, and the parameter Wind (from ISS) shows zero values ( as I understand it, this parameter (by default) is uploading on third-party resources: WU, AWEKAS... so everywhere "zero wind readings").
Give please advice.
Thanks.
Offline Mattk
Re: Meteobridge trouble with Anemometer transmitter kit
« Reply #1 on: February 16, 2019, 06:15:59 AM »
Which is your "windowind" sensor?
« Reply #2 on: February 16, 2019, 06:33:28 AM »
Sorry, I'm not sure what you mean?
Offline wvdkuil
  • Wim van der kuil
« Reply #3 on: February 16, 2019, 06:48:56 AM »
This part of the WiKi
https://www.meteobridge.com/wiki/index.php/Live_Data scroll down to
Historical Data => Color of sensor names on the left side does indicate if sensor is used for reporting of weather data to weather networks:
The green ones are the ones used for reporting.
You can click on the yellow wind one and select that one to use. It will turn green after that.
Wim
« Last Edit: February 16, 2019, 07:05:47 AM by wvdkuil »
« Reply #4 on: February 16, 2019, 08:59:37 AM »
Thank you very much! Earned! \:D/
Offline Mattk
« Reply #5 on: February 16, 2019, 04:34:20 PM »
As Wim has pointed out this user issue and as you apparently do not know what wind0wind is then I would suggest you spend some time reading the Wiki as you may also pick up a lot of other useful info
