Author Topic: Homeweatherstation weather34 template now bundled with NANOSD  (Read 650 times)
Offline weather34
« on: November 23, 2018, 12:50:57 AM »
Homeweatherstation weather34 template is now bundled with NANOSD
Boris has now bundled the template to be used locally within the meteobridge dashboard ,using a new chart system
that pulls data directly from meteobridge software/resources itself . You dont need a website to use this feature it is all built into the NANOSD
firmware and you still have the original options of sending the data to a website with any template you currently use.The feature doesnt remove any current options so if this otpion is not used/required the  meteobridge NANOSD does exactly as always and the dashboard template simply uses the resources of the NANOSD so no additional overheads,costs other than purchasing the NANOSD ..
more info here https://wiki.meteobridge.com/wiki/index.php/Forum and discussed here https://forum.meteohub.de/viewtopic.php?f=56&p=26605&sid=a142c190f1a0bd9a31fffdffeededc1c#p26605
Boris is also on hand to overcome any teething issues that arise, experience tells me nothing is ever rolled out without some teething
issues thats just the nature of weather websites and templates but with some good shared knowledge amongst this weather community these get resolved sooner or later ..
*Note Boris is the one who is supporting this not myself, i think he has managed to work how it all works as I did try and keep to the basic functionality of PHP without creating too complex scripts however its never wise to try and understand others code. In nearly 20 years of coding I have found no coder/developer adheres to the basic forms of coding each has there own style and signature in coding..
kudos Boris... the future is bright ..
« Last Edit: November 23, 2018, 12:53:09 AM by weather34 »
Offline Weatherman Mike
Re: Homeweatherstation weather34 template now bundled with NANOSD
« Reply #1 on: November 26, 2018, 02:01:30 PM »
Very Nice Brian!  It works like magic!   =D>
