Author Topic: Upgrade radiation shield for WS-2902  (Read 1515 times)
Offline Y42351
    • My weather station
« on: May 20, 2018, 10:52:49 PM »
Noticing that my Osprey afternoon temps are spiking a few degrees in the afternoon; any ideas on how to put a radiation shield on it? the SRS100LX is incompatible, it seems.
Ambient Weather WS-2902
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
Re: Upgrade radiation shield for WS-2902
« Reply #1 on: May 21, 2018, 02:53:42 AM »
It's a bummer that the shield isn't compatible with your shield, however I would say you have at least a couple of options. If you have some spare money on the side, I would say that buying or building a stevenson screen would be your best bet all together.
Building a stevenson screen discussion: https://www.wxforum.net/index.php?topic=32328.0
Buying a stevenson screen kit (here is just one option of several possible):  https://www.amazon.com/LABGO-Stevenson-Screen/dp/B016A120V4
If you are wanting to save money, you could check out a much less expensive way of building a radiation shield. This discussion came from someone using the same station that you have: https://www.wxforum.net/index.php?topic=32589.0
I hope this helps!  8-)
Joe Fitzwater
Chief Meteorologist for WVNS-TV 59 in Beckley, WV
Work Page on Facebook -> www.facebook.com/meteojoe
Work Page on Twitter -> https://twitter.com/meteojoe
Waterfalls -> www.wvfalls.com
Offline Y42351
« Reply #2 on: June 16, 2018, 09:48:14 PM »
Took a small  4" x 6" wicker style plastic basket, painted it white, cut a hole in the bottom of it the same size as the temp sensor, slid it up to the top, turned it 45 degrees, then took a couple of thin sticks and wedged them between the basket and the rain sensor, keeping a gap between the basket and sensor so the rain drains out. The temp sensor stays shaded now; time will tell if it made any difference!  :roll:
Offline alanb
« Reply #3 on: June 16, 2018, 11:01:58 PM »
How about giving us a picture of your modifications?
Alan - Ambient WS-2000, WH31E x5, WH31L, Ecowitt WN32(WH32E)
          Airthings Corentium Home Radon Detector 223
Offline Y42351
« Reply #4 on: June 17, 2018, 09:55:27 AM »
I'll try; going on a trip tomorrow, lots of stuff to do today to get ready! If not, then it'll be a couple of weeks!
