Author Topic: New Stuff - Ecowitt Has the Newest Fine Offset Hardware  (Read 58423 times)
Offline Lucy
Re: New Stuff - Ecowitt Has the Newest Fine Offset Hardware
« Reply #350 on: September 06, 2019, 06:40:46 AM »
Look's like I found a bug..
I know what has caused it.. I decided to check the calibration of the soil moisture sensor by putting it in a cup of water. It registered 100%, so it was good. I guess the graphs don't like '100%'?
If I refresh the page manually, it fixes it, but only until the next automatic refresh, then all of the graphs go upside down again.
Hi Mapantz, our engineer tested the soil moisture sensor with the 100% reading and didn't have the same situation as yours:
It's really strange.
Sorry that we couldn't find out the bug now.
If it happens again, please let us know.
Thank you.
Best Regards,
Lucy
Ecowitt Weather Instruments at: http://www.ecowitt.com/
FB: @ecowittsupport
Twitter: https://twitter.com/ecowittweather
Email: support@ecowitt.com
Offline Lucy
« Reply #351 on: September 06, 2019, 06:46:11 AM »
For the first time, I have been unable to update my firmware to 1.5.1. I get to the Updating splash and then the app will quit. I tried the last two days. [ You are not allowed to view attachments ]
Hi, we're sorry to see that. Could you please try to delete the WS View app and download the latest version to re-install it and try it again?
If it still fails, please let us know.
Thank you.
FB: @ecowittsupport
Offline MacGarage
  • SW Ohio
« Reply #352 on: September 06, 2019, 07:49:42 AM »
Is that iPhone?
It looks slightly different to Android version I have.
Could be a bug in the app (check for an update) and try doing a power cycle on the GW-1000 before doing the update
Yes, it is the iPhone app and the latest app they just released a couple of days ago. I rebooted the GW1000 and still no luck.
Perhaps the update is not released yet. It is not critical for me so waiting a few more days is not a problem.
Ecowitt WH2320E
AcuRite Atlas
Offline Eric971
« Reply #353 on: September 06, 2019, 07:58:02 AM »
Hello everyone, I just ordered hp2551 with several separate sensors following your comments.
I'm a (very) small farmer in France with goats I turn milk into cheese.
I have a question, though. Is it possible to prohibit the publication of one or more sensor on WU or ecowitt.net sites. I do not see the point of revealing my secrets of temperature or humidity refining or publish my housing conditions. 8-)
« Reply #354 on: September 06, 2019, 08:09:11 AM »
Your station will only report outdoor conditions to WU. Extra temp/hum sensors do not show up on WU. The outdoor conditions reported to WU can not be made private.
Your station will upload all sensors to Ecowitt.net (including extra sensors). You can choose if to make Ecowitt.net data private or public, but it is all or nothing, meaning you can't pick individual sensors to make private or public. With Ecowitt.net either the entire station is public or the entire station is private.
Come to think of it, I think it would be a good recommendation to Ecowitt to allow us to choose which sensors are private and which are public.
For those with Ambient Weather brand stations that report to Ambientweather.net it works a bit different. With Ambientweather.net when you make your station public the extra temp/hum sensors are not made public. But the PM2.5 air quality sensor is made public.
Offline Eric971
« Reply #355 on: September 06, 2019, 08:13:21 AM »
Thank you for your reply. It seems to me that it would be desirable to be able to choose what one wants to make public
Offline MacGarage
  • SW Ohio
« Reply #356 on: September 07, 2019, 10:39:07 AM »
Is that iPhone?
I was finally able to update the firmware...about three days after the updated iPhone app was released. Works fine now.
Ecowitt WH2320E
AcuRite Atlas
Offline Mapantz
    • Wareham Weather
« Reply #357 on: September 09, 2019, 11:17:36 AM »
Replacement console arrived today but I am still having signal issues. It will not pick up the soil moisture sensor unless i'm within 15/20ft away without any obstructions. It barely picks up the PM2.5 sensor either. It only shows the aerial icon but with zero  signal strength. It makes no sense because the PM and soil sensors are the closest to the console. The outdoor temp/humidity sensor is almost twice as far away and it picks that up absolutely fine.
https://postimg.cc/9RqpSLLR
New console is on the right.
« Last Edit: September 09, 2019, 01:08:06 PM by Mapantz »
Offline Mandrake
« Reply #358 on: September 09, 2019, 01:42:30 PM »
Yet, I notice the other console has full bars for your soil moisture sensor!
I have noticed that the console reception are very sensitive to Bluetooth devices transmitting nearby. In a similar vein do you have any DECT phones in the vicinity?
Curiously though when I do place a BT device that's active too close to my console not all the sensors get knocked out so it seems that the modulation (channels) used by console are prone to interference impact in different ways.
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline Mapantz
    • Wareham Weather
« Reply #359 on: September 09, 2019, 01:54:51 PM »
Not near the consoles, no.
Getting a bit pissed off with it now. I can't have the console in the place I want it because it will not pick up all the sensors. I have to have it in the porch to get decent signal, but I spend no time in it. The new console is worse than the old one for signal.
Previous to this station, I had a WeatherFlow station and a Netatmo station running alongside my Davis station. Both hubs were in the same room as the Davis console and I never had a single problem with RF on any device.
Offline Lucy
« Reply #360 on: September 09, 2019, 09:44:39 PM »
Hi Mapantz, sorry to hear that.
It's really strange. We have tested the console and signal very carefully before shipping.
Could you please help add the new console to the ecowitt.net?
Our engineer will try to check and find some solutions for you.
Sorry for the inconvenience caused.
Hope to hear from you soon.
Best Regards,
Lucy
FB: @ecowittsupport
Offline Jakon
« Reply #361 on: September 09, 2019, 10:23:06 PM »
Looks like there's something wrong with your soil moisture transmitter.The PM2.5 sensor send data every 10 minutes, so the towers grow slowly. Each time the transmitter data is received, the tower is added one grid.
Offline Eric971
« Reply #362 on: September 11, 2019, 08:12:04 AM »
At Galfert's prose reading, I added a GW1000 to my order.  I have two questions, though.
1. Given that I will have two indoor sensors (HP2551 and GW1000), will both be showed on app ?
2. The goal is to publish my data on a personal website and on windguru.  Could you indicate me tutorials wearable to a newbie with this material ?
Offline Mandrake
« Reply #363 on: September 11, 2019, 08:18:28 AM »
Both HP2551 and the GW-1000 will show up as separate devices on the WS-View app and as separate data sources on Ecowitt.net if that's what you are asking.
You can choose if you want to upload to other data sources, its not compulsory. You can choose either to send to a local server. I don't have a howto guide but there are plenty of posts on this site by folks who are doing this.
G1ZFO
« Reply #364 on: September 11, 2019, 11:03:18 AM »
Your HP2550A has live data on the WS-View??? I'm not aware that the HP2551/HP2550A/WS-2000 is capable of displaying live data on the WS-View app in the same manner that the GW1000 does. I don't own the HP2550A so I'm just asking for confirmation.
For those curious what the difference is between these:
HP2550 = Fine Offset model name
HP2551 = Ecowitt model name
WS-2000 = Ambient Weather model name
They are all three practically the same thing with some minor firmware differences. There are also other reseller brands of the same original Fine Offset HP2550.
By live view of sensors I'm referring to this screen:
« Last Edit: September 14, 2019, 11:22:52 AM by galfert »
Offline K7RMK
    • East Wilson Weather
« Reply #365 on: September 11, 2019, 11:27:26 AM »
WS-2000 = Ambient Weather name
Can you not give the air quality sensors a custom name like you can with the others that support multiple channels? I don't see the edit button.
Ecowitt GW2000 + Meteobridge on RPI 4B
Ecowitt HP2551-C Display Console
Ecowitt WH32-EP Outdoor Temp/Humidity Sensor + MeteoShield Pro Radiation Shield
Ecowitt WS68 Anemometer
Ecowitt WH40 Rain Gauge
Ecowitt WH41 Outdoor PM2.5 Air Quality Sensor
Ecowitt WH43 Indoor PM2.5 Air Quality Sensor
Ecowitt WH31 x4 Temp/Humidity Sensors
Ecowitt WH51 Soil Moisture Sensor
Ecowitt WH34S Soil Temperature Sensor
Ecowitt WN35 x2 Leaf Wetness Sensors
« Reply #366 on: September 11, 2019, 11:43:20 AM »
I just tried with latest 1.5.1 firmware and latest WS View version and you can't rename device channel names for the PM2.5.
Offline mark014
    • Weather conditions in Ślesin (Poland)
« Reply #367 on: September 26, 2019, 03:36:56 PM »
It may be useful for those users who are thinking about buying the HP3501 station:
[youtube]https://youtu.be/_g3KZNCuZZ8[/youtube]
Offline Mapantz
    • Wareham Weather
« Reply #368 on: September 26, 2019, 05:45:24 PM »
Had some weird temp spike this morning. However, nothing was logged on the console.
Offline Mandrake
« Reply #369 on: September 27, 2019, 03:57:23 AM »
looks like a calculation error in software somewhere since generally the Ecowitt software seems to ignore temps below 27C as far as Feels like is concerned.
Hard to tell if its a issue in the console or on the ecowitt.net website.
I would flag it to Lucy for someone to look at.
G1ZFO
Offline Lucy
« Reply #370 on: September 27, 2019, 06:28:02 AM »
Hi Mapantz, sorry for that.
Please don't worry and our engineer is checking your issue now.
We'll go back to you as soon as we find a solution.
Best Regards,
Lucy
FB: @ecowittsupport
Offline Mapantz
    • Wareham Weather
« Reply #371 on: September 27, 2019, 06:29:02 AM »
It went the other way this morning..
Definitely not a console issue as it's not connected to the internet. The console hasn't logged anything like that. So it's either the GW-1000 or it's something Ecowitt's side.
« Reply #372 on: September 27, 2019, 07:08:55 AM »
Perhaps you are picking up a stray signal from something else. Do you have an old station still running with perhaps batteries still in it? Or maybe it is not a problem with the GW1000, but rather it is a problem with your temperature sensor.
Offline Mapantz
    • Wareham Weather
« Reply #373 on: September 27, 2019, 07:22:48 AM »
No other sensors apart from the Davis.
If it was a problem with the temp/humidity sensor, why doesn't it get logged on the consoles? I'm logging data at 1 minutes intervals and everything looks healthy.
« Reply #374 on: September 27, 2019, 08:11:58 AM »
Okay. I guess we'll wait for Lucy to hopefully have some answers.
