Author Topic: Another Issue: Yesterday High and Low wrong I think related to V281 WD  (Read 512 times)
Offline tnwxman
  • KK4QXH
    • Weather for Lebanon, TN 37087
Just noticed another problem. Yesterdays High and Low are in correct. Should be 90.4 and 70.2. Look at the image. Since updating to WD v281 I have the following issues: The WD almanac works in WD but will not update the web page. I have since removed that feature as Brian has had no solution to this point. The rainfall average differential script is giving the wrong calculations, and the feels like heat index is not appearing under the temperature. Could this be some type of tag issue change since V.81 to v.281?
Any ideas or suggestions for these issues?
http://lebanontnwx.org
Thanks.
Bob
Bob
KK4QXH
Offline jmcmurry
  • Jim McMurry
    • Juneau County Weather
Bob,
I think it could definitely be an issue with some of the tags.  The new compiler seems to do some things differently and requires some changes.
It will help Brian if you can provide a list of the tags being used so he can investigate them.
- Jim
Offline tnwxman
  • KK4QXH
Hi Jim,
Thanks for the suggestion. Here is the problems I am not sure how to find what they are? Do you know how I can determine them?
Bob
Bob
KK4QXH
